I have enabled TLS for my TCP input which is receiving syslogs. That is working and I can see the messages on the web interface. The problem comes in when I enable client authentication. I have spent an entire day working on this and looking at the different suggestions but I don’t quite understand which file/folder ‘TLS Client Auth Trusted Certs (File or Directory)’ is supposed to point to. Is it on the client’s side or on the graylog server? Do I need to create a keystore for the key/cert pair?
Currently, I have it pointing ot the client cert but keep getting an error as shown below. The certificate is signed by own CA. I realise this question has been asked enough times - I’m willing to write up the doco for this once I get it running.
2017-06-09T15:29:26.652+08:00 WARN [AbstractTcpTransport] client auth configured, but no authorized certificates / certificate authorities configured
2017-06-09T15:29:27.568+08:00 ERROR [NettyTransport] Error in Input [Raw/Plaintext TCP/5938accf4ab0862eecda0c9d] (channel [id: 0x9f38aee0, /X.X.X.X => /X.X.X.X])
javax.net.ssl.SSLHandshakeException: null cert chain
at sun.security.ssl.Handshaker.checkThrown(Handshaker.java:1478) ~[?:1.8.0_131]
at sun.security.ssl.SSLEngineImpl.checkTaskThrown(SSLEngineImpl.java:535) ~[?:1.8.0_131]
at sun.security.ssl.SSLEngineImpl.readNetRecord(SSLEngineImpl.java:813) ~[?:1.8.0_131]
at sun.security.ssl.SSLEngineImpl.unwrap(SSLEngineImpl.java:781) ~[?:1.8.0_131]
at javax.net.ssl.SSLEngine.unwrap(SSLEngine.java:624) ~[?:1.8.0_131]
at org.jboss.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1219) ~[graylog.jar:?]
at org.jboss.netty.handler.ssl.SslHandler.decode(SslHandler.java:852) ~[graylog.jar:?]
at org.jboss.netty.handler.codec.frame.FrameDecoder.callDecode(FrameDecoder.java:425) ~[graylog.jar:?]
at org.jboss.netty.handler.codec.frame.FrameDecoder.messageReceived(FrameDecoder.java:303) ~[graylog.jar:?]
at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) ~[graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [graylog.jar:?]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [graylog.jar:?]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [graylog.jar:?]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [graylog.jar:?]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [graylog.jar:?]
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337) [graylog.jar:?]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [graylog.jar:?]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [graylog.jar:?]
at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [graylog.jar:?]
at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
