Send java Application logs to graylog
I am using 2 instances, in first instance is with java application container (TOMCAT application with hello word text) and in second instance i have setup graylog. currently i am not using any log framework in java application , i have few question
  • which framework is best to use with graylog
  • how do i send framework logs to graylog
  • as i am using the Jenkins to automate the above process, is it possible that i can create a input dynamically and create dashboard.
  • you should use the framework that fits into your environment.
  • how to send depends on the framework
    • create input in Graylog first to be able to receive message
    • send messages from your application
  • use the API or content packs to generate that on creation.
i am new in devops and java, so i am not aware which framework suits me best, currently i just displaying hello word from tomcat so i am open for any logging framework. i was able to send rsyslog logs to graylog, but i dont know how to send tomcat logs to which is in container
    /var/lib/docker/devicemapper/mnt/<some id>/rootfs/usr/local/tomcat/logs
The above are only a few possible solutions - and you need to make the steps yourself.
i have installed filebeat on java application intance (NOT in container) configure the filebeat.yml as given but no success
###################### Filebeat Configuration Example #########################
# This file is an example configuration file highlighting only the most common
# options. The filebeat.reference.yml file from the same directory contains all the
# supported options with more comments. You can use it as a reference.
# You can find the full configuration reference here:
# https://www.elastic.co/guide/en/beats/filebeat/index.html
# For more available modules and options, please see the filebeat.reference.yml sample
# configuration file.
#=========================== Filebeat inputs =============================
filebeat.inputs:
# Each - is an input. Most options can be set at the input level, so
# you can use different inputs for various configurations.
# Below are the input specific configurations.
- type: log
  # Change to true to enable this input configuration.
  enabled: false
  # Paths that should be crawled and fetched. Glob based paths.
  paths:
    - /var/lib/docker/devicemapper/mnt/*/rootfs/usr/local/tomcat/logs/*
    #- c:\programdata\elasticsearch\logs\*
  # Exclude lines. A list of regular expressions to match. It drops the lines that are
  # matching any regular expression from the list.
  #exclude_lines: ['^DBG']
  # Include lines. A list of regular expressions to match. It exports the lines that are
  #include_lines: ['^ERR', '^WARN']
  # Exclude files. A list of regular expressions to match. Filebeat drops the files that
  # are matching any regular expression from the list. By default, no files are dropped.
  #exclude_files: ['.gz$']
  # Optional additional fields. These fields can be freely picked
  # to add additional information to the crawled log files for filtering
  #fields:
  #  level: debug
  #  review: 1
### Multiline options
  # Mutiline can be used for log messages spanning multiple lines. This is common
  # for Java Stack Traces or C-Line Continuation
  # The regexp Pattern that has to be matched. The example pattern matches all lines starting with [
  #multiline.pattern: ^\[
  # Defines if the pattern set under pattern should be negated or not. Default is false.
  #multiline.negate: false
  # Match can be set to "after" or "before". It is used to define if lines should be append to a pattern
  # that was (not) matched before or after or as long as a pattern is not matched based on negate.
  # Note: After is the equivalent to previous and before is the equivalent to to next in Logstash
  #multiline.match: after
#============================= Filebeat modules ===============================
filebeat.config.modules:
  # Glob pattern for configuration loading
  path: ${path.config}/modules.d/*.yml
  # Set to true to enable config reloading
  reload.enabled: false
  # Period on which files under path should be checked for changes
  #reload.period: 10s
#==================== Elasticsearch template setting ==========================
setup.template.settings:
  index.number_of_shards: 3
  #index.codec: best_compression
  #_source.enabled: false
#================================ General =====================================
# The name of the shipper that publishes the network data. It can be used to group
# all the transactions sent by a single shipper in the web interface.
#name:
# The tags of the shipper are included in their own field with each
# transaction published.
#tags: ["service-X", "web-tier"]
# Optional fields that you can specify to add additional information to the
# output.
#fields:
#============================== Dashboards =====================================
# These settings control loading the sample dashboards to the Kibana index. Loading
# the dashboards is disabled by default and can be enabled either by setting the
# options here, or by using the `-setup` CLI flag or the `setup` command.
#setup.dashboards.enabled: false
# The URL from where to download the dashboards archive. By default this URL
# has a value which is computed based on the Beat name and version. For released
# versions, this URL points to the dashboard archive on the artifacts.elastic.co
# website.
#setup.dashboards.url:
#============================== Kibana =====================================
# Starting with Beats version 6.0.0, the dashboards are loaded via the Kibana API.
# This requires a Kibana endpoint configuration.
setup.kibana:
  # Kibana Host
  # Scheme and port can be left out and will be set to the default (http and 5601)
  # In case you specify and additional path, the scheme is required: http://localhost:5601/path
  # IPv6 addresses should always be defined as: https://[2001:db8::1]:5601
  #host: "localhost:5601"
#============================= Elastic Cloud ==================================
# These settings simplify using filebeat with the Elastic Cloud (https://cloud.elastic.co/).
# The cloud.id setting overwrites the `output.elasticsearch.hosts` and
# `setup.kibana.host` options.
# You can find the `cloud.id` in the Elastic Cloud web UI.
#cloud.id:
# The cloud.auth setting overwrites the `output.elasticsearch.username` and
# `output.elasticsearch.password` settings. The format is `<user>:<pass>`.
#cloud.auth:
#================================ Outputs =====================================
# Configure what output to use when sending the data collected by the beat.
#-------------------------- Elasticsearch output ------------------------------
#output.elasticsearch:
  # Array of hosts to connect to.
 # hosts: ["localhost:9200"]
  # Optional protocol and basic auth credentials.
  #protocol: "https"
  #username: "elastic"
 #password: "changeme"
#----------------------------- Logstash output --------------------------------
output.logstash:
  # The Logstash hosts
  hosts: ["myip:5014"]
  # Optional SSL. By default is off.
  # List of root certificates for HTTPS server verifications
  #ssl.certificate_authorities: ["/etc/pki/root/ca.pem"]
  # Certificate for SSL client authentication
  #ssl.certificate: "/etc/pki/client/cert.pem"
  # Client Certificate Key
  #ssl.key: "/etc/pki/client/cert.key"
#================================ Logging =====================================
# Sets log level. The default log level is info.
# Available log levels are: error, warning, info, debug
#logging.level: debug
# At debug level, you can selectively enable logging only for some components.
# To enable all selectors use ["*"]. Examples of other selectors are "beat",
# "publish", "service".
#logging.selectors: ["*"]
#============================== Xpack Monitoring ===============================
# filebeat can export internal metrics to a central Elasticsearch monitoring
# cluster.  This requires xpack monitoring to be enabled in Elasticsearch.  The
# reporting is disabled by default.
# Set to true to enable the monitoring reporter.
#xpack.monitoring.enabled: false
# Uncomment to send the metrics to Elasticsearch. Most settings from the
# Elasticsearch output are accepted here as well. Any setting that is not set is
# automatically inherited from the Elasticsearch output configuration, so if you
# have the Elasticserch output configured, you can simply uncomment the
# following line.
#xpack.monitoring.elasticsearch:
you should not read the containers files from outsite - that is something that shouldn’t be done.
Is your Graylog listening in myip and Port 5014 with beats input? Can your sender - the host where filebeat is running reach that ip and port?
its working now, i forgot to enable the input configuration.
currently i am using this configuration for java application container.
FROM tomcat:8.0.20-jre8
RUN mkdir /usr/local/tomcat/webapps/myapp
COPY target/HelloWorldWebApp.war /usr/local/tomcat/webapps/HelloWorldWebApp.war
CMD ["catalina.sh", "run"]
EXPOSE 8080
where i need to define filebeat installation step, if all went well than what is the best way to update filebeat.yml file, currently i am using AWS ami for graylog which goes up with the help of terraform.
as i am using jenkins to automate the complete process, i can not do manul ssh and update the filebeat.yml file
