i have a problem with graylog 2.3 search.
when i try to search something i can see the result on the left side (like how many messages are found)
but not the actual messages. after that when i try to navigate to another part of graylog like alerts or dashboards it doesnt work.
i didnt see any errors in the log files
Please be less specific. I can’t think of anything with all these details!
Screenshots would be good. Elaborating on the issue would be good, including some examples. Posting your logs would also be good.
currently i am unable to upload pictures due to company policy but i can tell you that unlike before i don’t see any errors added to the log while i am expiriencing this issue. i can also say that the "allow_highlighting " is set to true and it doesnt work. and i have this problem only in the 2.3 version and not in the one server that has the 2.2.3 version.
if you need more details to help me solve this issue please let me know and i will try to provide.
i found some errors regarding the quick valule plus plugin.
the 2.3 servers has the new plugin 3.0.1 and when i delete it from the server the problem is solved
the 2.2.3 server has the 2.1.0 plugin version
vice.java:176) [graylog.jar:?]
2017-11-20_06:51:37.71545 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
2017-11-20_06:51:37.71666 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
2017-11-20_06:51:37.71745 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
2017-11-20_06:51:37.71847 DEBUG [SessionAuthenticator] Found session 9a96c20b-00e9-47a9-944d-e0bd69d7d076 for user name admin%TRACE
[ChainingClassLoader] Class org.graylog.plugins.quickvaluesplus.QuickValuesPlusPluginConfiguration not found% java.lang.ClassNotFoun
dException: org.graylog.plugins.quickvaluesplus.QuickValuesPlusPluginConfiguration
2017-11-20_06:51:37.71898 at java.net.URLClassLoader.findClass(URLClassLoader.java:381) ~[?:1.8.0_131]
2017-11-20_06:51:37.72033 at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_131]
2017-11-20_06:51:37.72135 at java.net.FactoryURLClassLoader.loadClass(URLClassLoader.java:814) ~[?:1.8.0_131]
2017-11-20_06:51:37.72268 at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_131]
2017-11-20_06:51:37.72362 at org.graylog2.shared.plugins.ChainingClassLoader.loadClass(ChainingClassLoader.java:46) [graylog.j
ar:?]
2017-11-20_06:51:37.72513 at java.lang.ClassLoader.loadClass(ClassLoader.java:357) [?:1.8.0_131]
2017-11-20_06:51:37.72605 at org.graylog2.rest.resources.system.ClusterConfigResource.classFromName(ClusterConfigResource.java
:185) [graylog.jar:?]
2017-11-20_06:51:37.72707 at org.graylog2.rest.resources.system.ClusterConfigResource.read(ClusterConfigResource.java:99) [gra
ylog.jar:?]
2017-11-20_06:51:37.72762 at sun.reflect.GeneratedMethodAccessor177.invoke(Unknown Source) ~[?:?]
2017-11-20_06:51:37.72903 at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_1
31]
2017-11-20_06:51:37.72952 at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_131]
2017-11-20_06:51:37.73067 at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(Resour
ceMethodInvocationHandlerFactory.java:81) [graylog.jar:?]
2017-11-20_06:51:37.73114 at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJav
aResourceMethodDispatcher.java:144) [graylog.jar:?]
2017-11-20_06:51:37.73281 at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJa
vaResourceMethodDispatcher.java:161) [graylog.jar:?]
2017-11-20_06:51:37.73366 at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ObjectOutInvoker.
doDispatch(JavaResourceMethodDispatcherProvider.java:176) [graylog.jar:?]
2017-11-20_06:51:37.73519 at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(Abstract
JavaResourceMethodDispatcher.java:99) [graylog.jar:?]
2017-11-20_06:51:37.73701 at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [g
raylog.jar:?]
2017-11-20_06:51:37.73779 at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [gr
aylog.jar:?]
2017-11-20_06:51:37.73887 at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [gr
aylog.jar:?]
2017-11-20_06:51:37.74048 at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
Since that’s a third-party plugin, feel free to inform the author about the issue:
