Are there any restrictions on searching in graylog?
Because i tried to find message with text having double colons ( :: ) and not get any results, but if i look by timestamp i can see it.
There is no errors in graylog or elasticsearch logs.
My guess is that because the message field is an indexed field it ignores the puncuation (the tldr is that it breaks aparts all the words, but punctuation spacing etc is ignored.
If you wanted to search it you would need to copy the message field into another field that was set to the datatype of keyword and then you should be able to find it in that.
