Searching special characters
Hi all,
I try to understand escaping and wildcards but seem to miss something very basic.
For example I do not even manage to search for a “.” or “-“ character in the message field.
Neither one of the following expressions returns all messages, that contain the character:
or
Thanks for your help
Kirt
(I am using the virtual appliance Graylog 3.2.4+a407287)
Did you check docs?:
https://docs.graylog.org/en/3.2/pages/searching/query_language.html
https://www.elastic.co/guide/en/elasticsearch/guide/2.x/_wildcard_and_regexp_queries.html
https://www.elastic.co/guide/en/elasticsearch/reference/6.8/query-dsl-regexp-query.html#regexp-syntax
According to https://docs.graylog.org/en/3.2/pages/searching/query_language.html I would have expected the following:
Searching for string “testing…”
Query: testing…
Expected: returns messages
Result: returns messages
Query: testing
Expected: not returning messages (as “…” is part of the string with no white space between)
Result: still returning messages
Query: *…
Expected: returning messages (as * should act as a wildcard for the substring “testing”)
Result: not returning messages
As my queries do not employ a regular expression, I would have expected “.” to be a standard character.
What am I missing?
Kirt
Hi all,
any hints on how I do search for “testing…” without finding “testing”? (I.e, require the “…”).
I do not get the concept at all :frowning:
Kirt
he @Kirt
your leading wildcard search will only work if you have that enabled in Graylog. When you search for the string - you should quote that string. Like described in the docs.
Thanks for the asnwer,Jan.
My example with the leading wildcard was not carfully picked. Sorry. Yes, I saw that leading wildcards have to be enabled.
What I do still not understand, is the very simple basic search for a string, that contains “…” (three points).
Text in the log e.g. is “Some text test…” (Without the quotes).
What will I have to enter into the search field to find all lines with “test…” but not with only “test”. (without the quotes).
Kirt
he @Kirt
the main question is - do you search in the message field or do you search in a different field?
The message field is analyzed field that means that the content is split into terms based on the active tokenizer.
Overview:
https://www.elastic.co/guide/en/elasticsearch/reference/6.8/analysis-tokenizers.html
Default Tokenizer
https://www.elastic.co/guide/en/elasticsearch/reference/6.8/analysis-standard-tokenizer.html
As this is based of words (see links above) your dots are not searchable. Because they are no words.
Should the content be in a non analyzed field where the content is simple seen as a string, your search would be possible.
Thanks Jan! This explains what I see. I do indeed search the full_message and message fields.
After having a short look at the tokenizer: Wouldn’t it be better to use the whitespace tokenzier when dealing with log messages? While “test” and “test.” might be very close in a spoken language, it’s likely to be completely different in a log file. This is just asking your opinion.
Will there be another way to search for “test…” in analyzed field?
Thanks again, as I finally know the reason why my search is not working as expected.
Kirt
he @Kirt
you could change the tokenizer and check if that is better for you. We did not change the default tokenizer to not change/break the behaviour and make it inconsistence for running setups.
