Search by json field does not work
I was enable leading wildcard searches but it does not work with json fields.
I have field _params:
%D0%B8%D0%B7%D0%BE%D0%B1%D1%80%D0%B0%D0%B6%D0%B5%D0%BD%D0%B8%D0%B5
So, I try find: “click_id”: “62e698b4-2608-4cf3-8a07-5123c329fdb2”:
But this query does not work with json field. How can I do this?
Graylog does not know about json in the search - so you would need to search different.
https://docs.graylog.org/en/3.1/pages/queries.html
_params:"62e698b4-2608-4cf3-8a07-5123c329fdb2"
The above should work but I’m not 100% sure because I do not have the data available.
I would - if you have that json in that and need to search regular on that fields - use a processing pipeline to make those key-value into their own fields.
