Dear All,
Recently I upgraded to 2.4.5+8e18e6a
Now it’s a little bit tricky to save a search result. Once you selected a saved searched criteria the “Save Search Criteria” button disappears. It is replaced by a “Saved search” button, even if the search string was modified. The only way to save a new criteria is to copy the search string, press the “Search” button in the top menu and paste the string into the search field. Now you can save this criteria as a new item.
Would be nice if this handling could be made easier.
Kind regards
Hans
