Hi Team,
Do we have an option to run the graylog application in multiple instances on the same server?
Regards,
Manju
Hi Team,
Regards,
Manju
Yes, that should work if you configure Graylog and its inputs to use completely separate network interfaces, local paths (e. g. node_id_file, message_journal_dir, etc.), and their own MongoDB database.
