Rsyslog -> syslog input fails parsing facility correctly sometimes
I’m trying to debug an issue where some messages have the field facility set correctly while others fail to set a correct facility.
Example of correctly parsed facility
Parsed facility: security/authorization
Parsed facility_num: 10
Full message from syslog host:
<86>1 2021-09-22T16:11:34.578583+02:00 mylogclient sudo - - - pam_unix(sudo:session): session closed for user root
Example of incorrectly parsed facility
Parsed facility: type=USER_END msg=audit(1632319894.575
<14>1 2021-09-22T16:11:34.579213+02:00 mylogclient audispd - - - node=mylogclient type=USER_END msg=audit(1632319894.575:2457): pid=26515 uid=0 auid=1000 ses=60 subj==unconfined msg='op=PAM:session_close grantors=pam_permit,pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
How do I proceed debugging this issue?
Environmental information
All messages in this example are coming from the same host which is running Debian 10 with rsyslogd 8.1901.0 (aka 2019.01) using the following configuration:
$PreserveFQDN on                         # fixes FDQN issue
$ActionQueueType            LinkedList   # use asynchronous processing
$ActionQueueFileName        remote       # unique name prefix for spool files
$ActionQueueMaxFileSize     50m
$ActionQueueMaxDiskSpace    512m         # 512M space limit (use as much as possible)
$ActionResumeRetryCount     -1           # infinite retries if host is down
$ActionQueueSaveOnShutdown  on           # save messages to disk on shutdown
$ActionQueueTimeoutEnqueue  0            # Drop messages with no wait when they can’t be queued
*.*     @@mylogserver;RSYSLOG_SyslogProtocol23Format
Package versions
The graylog server is running Debian 11.
  • Graylog 4.1.5-1 (installed from graylog repository)
  • MongoDB 4.4.9 (installed from mongodb repository)
  • Elasticsearch 7.15.0 (installed from elasticsearch repository)
As a new user I couldn’t embed more than 1 picture. Sending in the picture of the correctly parsed message.
Hello && welcome
Need to ask a couple of questions.
  • What type of Input are you using to ingest logs?
  • Are you aware of the supported version of Elasticsearch?
  • Do you have any extractors/pipeline created on you Input?
I personally haven’t tried version 7.15 yet
Syslog TCP and/or UDP. Both have the same result.
Thank you, I actually wasn’t aware, I have removed Elasticsearch 7 and installed Elasticsearch 6.8.19 from Elasticsearch repo, removed indexes and started with new indexes, still the same.
Yes, but none of them should adjust the facility field. Just to be on the safe side I have removed all extractors from the Syslog TCP input and removed all pipeline connections, looks like this works. Gonna check all sorts of messages and report back.
I was asking about extractors/pipelines was because the field data you shown above looks like it truncate.
As for your Rsyslog I assume you are aware of these types of configurations below. Reason I ask was I’m not sure when you changed Inputs types that you changed you Rsyslog configuration file when testing.
*.* @@somehost:5140  //UDP connection
*.* @somehost:5140  //TCP  connection
For troubleshooting purposes, have you tried to use different log shippers (i.e. Nxlog, FileBeat)? If so do you get the same results?
