I know there’s an archiving option with Graylog Enterprise, but how do you do that for a company that doesn’t have the budget?
I read that there is a method of archiving indexes using Curator (Graylog with curator? ) but there are a lot of things I don’t understand.
What is a noop rotation strategy? And is what you really need to do as many conf files as specify here:
Graylog2:master ← Graylog2:noop-rotationstrategy
opened 04:05PM - 04 Oct 17 UTC
And then, my server is almost saturated in disk space, will I have to start a recalculation of all my index ranges?
Thank you
To repeat my question, I just saw that Curator must be used with a HOT/WARM architecture, however my hard drive is already almost saturated
Can I adapt my architecture without deleting data?
Thank you
reimlima
(Dummy)
March 15, 2021, 3:10pm
3
Hi @Cruciani_Elliot I had a similar problem a while ago.
Here’s what I did to solve it:
I was unsuccessful on this issue, so I had to appeal for an “alternative solution” with some “wires” here and there:
I created a step in the “curator” that forces the migration of any index and shard with less than 1 day to the “hot” nodes.
And I created a shell script that applies the settings I need in the newest created index.
It is not a seamless solution, but it solves my problem. I will keep an eye out for new Graylog updates in the hope that this feature I need will appear in new versi…
Hi @reimlima , thank you for the anwser,
what you sent me is going to be very useful to me, however I do not believe that you are talking in the processing of indexes that are already created and that is what may cause me problem since I would like to archive them without deleting them
Thank you
reimlima
(Dummy)
March 16, 2021, 11:00am
5
Hi @Cruciani_Elliot ,
Yes, this is about created indexes, I just forgot to mention that you have to configure index rotation in your Graylog UI (sorry about that).
To solve the problem I had to choose “Rotation period: P1D (1 day, a day) ” as an option.
You can run all this process manually, so you don’t have to wait until next day to see if it works.
thank you @reimlima
I have a last question: I didn’t understood the action:allocation on your curator config
reimlima
(Dummy)
March 16, 2021, 5:42pm
7
so, “allocation” is one type of actions Curator can do, it tells Curator to migrate your index from one node to another based on filters you define.
See my configuration as an example:
action: allocation
description: "Apply shard allocation filtering rules to the hot log"
options:
key: box_type
value: warm
allocation_type: require
wait_for_completion: True
max_wait: 3600
timeout_override:
continue_if_exception: False
disable_action: False
allow_ilm_indices: True
filters:
- filtertype: pattern
kind: prefix
value: graylog_
- filtertype: age
source: creation_date
direction: older
unit: days
unit_count: 1
A little of explaining, basically it will migrate indexes named like “graylog_” and older than 1 day from hot nodes to warm nodes.
Curator will know the nodes based on the key “box_type” with value “warm”.
You must tag your nodes using the option in the elasticsearch.yml file:
node.attr.box_type: hot # to hot nodes
And
node.attr.box_type: warm # to, you guess it, warm nodes
It strongly recomended that you take a moment to read the Curator’s doc to understand how to configure and run it.
Hi @reimlima , thank you for the anwsers, I’ll try to do that
