hi, we have different ports in this two parameters ( rest_listen_uri = http://172.16.20.58:9000/api/ , web_listen_uri = http://172.16.20.58:9200/ ) .
so there are two questions:
is it safe for cluster to change on the fly web listen uri to http://172.16.20.58:9000 ? Can there be problems with the cluster?
We have tried to setup SSL connection trough nginx. so on version 2.0.1 this config works
server {
listen 80;
listen 443 ssl http2;
server_name log-sys.example.ru;
ssl_certificate /etc/ssl/certs/star_example_ru.chained2.crt;
ssl_certificate_key /etc/ssl/private/star_example.key;
ssl_prefer_server_ciphers on;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:ECDH+3DES:DH+3DES:RSA+AESGCM:RSA+AES:RSA+3DES:!aNULL:!MD5;
location /api/ {
proxy_pass http://172.16.20.41:12900/;
location / {
proxy_set_header X-Graylog-Server-URL https://log-sys.example.ru/api;
proxy_pass http://172.16.20.41:9000;
if ($ssl_protocol = "") { rewrite ^/(.*) https://$host/$1 permanent;}
but on newer version (2.2.3) same config doesn`t work .
server {
listen 80;
server_name log.example.ru;
location /api/ {
proxy_pass http://172.16.20.58:9000/api;
location / {
proxy_set_header X-Graylog-Server-URL https://log.example.ru/api;
proxy_pass http://172.16.20.58:9200;
Where we have a mistake ? or what we do wrong? thx
