Replace timestamp from another indexed field
Description of your problem
I am a newbie to Graylog. I have graylog/mongodb/es running in docker using docker-compose.yaml (listed). I have WebSphere Liberty writing logs in JSON format. I used filebeat to point the liberty log file to the Beats input that I created in Graylog:
filebeat.inputs:
- type: log
  enabled: true
  paths:
    - /wlp-javaee7-19.0.0.12/usr/servers/browsi-git-maven/logs/messages.log
output.logstash:
 hosts: ["192.168.1.165:5044"]
Description of steps you’ve taken to attempt to solve the issue
In my Beats input, I created a JSON extractor to take the message field (which was already JSON) and extract the keys/values from it. Works great.
Now, I would like to take one of those extracted fields, namely:
  • ibm_datetime
and override the timestamp field in Graylog.
What is the best way of overriding the timestamp field with one of the JSON indexed fields?
ibm_datetime fields has the following format:
2021-09-08T19:32:22.707-0400
Operating system information
  • macOS Big Sur
  • Docker
Package versions
version: '3'
services:
  mongo:
    image: mongo:4.2
    networks:
      - graylog
  # Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/7.10/docker.html
  elasticsearch:
    image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
    environment:
      - http.host=0.0.0.0
      - transport.host=localhost
      - network.host=0.0.0.0
    ulimits:
      memlock:
        soft: -1
        hard: -1
    deploy:
      resources:
        limits:
          memory: 1g
    networks:
      - graylog
  graylog:
    image: graylog/graylog:4.1
    environment:
      - GRAYLOG_PASSWORD_SECRET=somepasswordpepper
      # Password: admin
      - GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
      - GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
    entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 --  /docker-entrypoint.sh
    networks:
      - graylog
    restart: always
    depends_on:
      - mongo
      - elasticsearch
    ports:
      - 9000:9000
      # Syslog TCP
      - 1514:1514
      # Syslog UDP
      - 1514:1514/udp
      # Beats TCP
      - 5044:5044
      # GELF TCP
      - 12201:12201
      # GELF UDP
      - 12201:12201/udp
networks:
  graylog:
    driver: bridge
Looks like I should use pipeline rule with set_field for timestamp field.
Hello @corporate_gadfly
I would have to agree with you on the pipeline. Maybe something like this might help.
rule “ibm_datetime”
    true
    let new_date = parse_date(to_string($message.http_time), “yyyy-MM-dd’T’HH:mm:ss”, "CET,UTC,etc...");
    set_field(“timestamp”, new_date);
EDIT: I found this here.
Hope that helps.
@gsmith is correct, but use this correct format for your field format 2021-09-08T19:32:22.707-0400
let new_date = parse_date(to_string($message.ibm_datetime), "yyyy-MM-dd'T'HH:mm:ss.SSSZZ");
set_field("timestamp", new_date);
Thx @shoothub , @gsmith .
Love it when a plan comes together. Will try it out this morning.
TY, both.
For completeness, I did the following:
  • Since I’m using JSON extractor, I made sure to move Message Filter Chain before Pipeline Processor in System → Configurations
  • To match the ibm_datetime field, my rule looks like following:
rule "replace timestamp"
  has_field("ibm_datetime")
  let timestamp = parse_date(to_string($message.ibm_datetime), "yyyy-MM-dd'T'HH:mm:ss.SSSZ");
  set_field("timestamp", timestamp);
@shoothub
Thanks for catching my mistake. I should have known better.
