Regex search not working?
Graylog beginner here. I have a single-node 6.2.2 instance (opensearch) set up and working.
I’m trying to search for messages using a regex. For example:
Actual message field stored in db:
sw02-desk 942a6f4e4a66,USW-Flex-2.5G-5-2.1.8.971: TLS-S: Starting TLS server on port 22. free_heap 137815
Search: message:/starting.*port/
This yields NO results. However, when I search for just message:/starting/ I do find the messages (plust a lot more that I don’t want).
I have tried:
message: /starting.*port/
message:/starting.*port/      << no space after fieldname
message: /Starting.*port/     << case sensitive?
message: /.*starting.*port.*/
message: /starting*port/
Even regular string globs are not working
message: "starting*port"
I have no idea why this isn’t working. Some sort of database/index configuration problem?
with your regex you define the message to start with “starting”. give
message:/.*Starting.*port.*/
a chance. This query is highly wasting CPU, as it has three wildcards in it.
If you look at my original post you will see that I tried that query already (it’s the 4th one down) and it does not work.
Your regex would work with another field, but the message field is quite different, it is a different OpenSearch analyzer, so the field is not parsed like others.
It is not a regex but I think you can try:
message:"Starting TLS server on port"
Thanks but we’re getting off course of the original question: Is it possible to search the message field somehow using regex? How can it be done? If the answer is “no” I am a bit perplexed how to properly slice and dice this large data set, do we need to use another external tool?
I’d suggest to copy that field “message” into another field and do the regex there? A pipeline with a little rule will do the job.
As there are other relevant information in that message I’d recommend to parse the whole message into different fields:
source:sw02-desk
don’t_know:USW-Flex-2.5G-5-2.1.8.971
service:TLS-S
source_port:22
free_heap:137815
event_action:“starting TLS Server”
If it is parsed like this you just could search for event_action:“starting TLS Server” and have the correct result.
Thanks. I admit I really don’t understand “why” I have to duplicate the message field to another field just so I can regex search on it. Is this expected? What are other people doing for complex searching? Everyone is making custom pipelines and duplicating the data? Or am I “doing it wrong” here? Trying to learn so please excuse my ignorance.
Having things properly parsed in different fields allows you to fill your aggregations with the results. This needs to be done during the processing of the logs and can not be done afterwards.
Opensearch, the database for the logs, has some special properties on some fields. For you own fields you might adjust those propertied in the “Index Set Field Type Profiles”.
@ihe any chance you could post a screenshot / example of such a pipeline rule that copies the message field?
of course:
rule "copy message field"
  true
  // you might put a better condition here, like an input id, example:
  // to_string($message.gl2_source_input) == "71785a71bc3a548726b35c9b44"
  set_field("message_copy", to_string($message.message));
