Mr_Reyes
(John Reyes)
October 2, 2017, 9:55am
1
Hey There
i’m having some problems with my config.
when i set the rest_api to the external ip (and i have nat the port 12900, i can access the web interface, but not start my udp syslog.
if i set it to the internal ip:12900 the weblogin just stalls af loading…
if i access it here from the same subnet, everything works fine.
how to i configure it to work behind a nat?
jochen
(Jochen)
October 2, 2017, 11:19am
2
Try using the following configuration:
rest_listen_uri = http://0.0.0.0:9000/api
web_listen_uri = http://0.0.0.0:9000/api
web_endpoint_uri = http://<Public IP address or host name>:9000/api
# This setting only if you have a single Graylog node and not a cluster
rest_transport_uri = http://127.0.0.1:9000/api
Mr_Reyes
(John Reyes)
October 2, 2017, 12:36pm
3
but my rest api port has been 12900?
jochen
(Jochen)
October 2, 2017, 12:37pm
4
Then change the settings accordingly, if you want to…
Mr_Reyes
(John Reyes)
October 2, 2017, 12:50pm
5
rest_listen_uri = http://<LAN address>:12900
web_endpoint_uri = http://<Public address>:12900
rest_transport_uri = http://<LAN address>:12900
did the trick
thanks for the help!
system
(system)
Closed
October 16, 2017, 12:50pm
6
