Problems with Graylog Docker image
:joy: you really funny no explanation just link ! really not helpful at all. i know these link already !
a little explanation(verbose) that all i asking !
The documentation describes step-by-step how to build a custom Docker image based on the official Graylog Docker image with custom plugins.
If you don’t describe at which step you’re stuck, we can’t help you.
Hello, what the stream rule should be to route only messages containing words ddclient and success ! thanks
The strings “success” and “SUCCESS” are quite different and stream rules are case sensitive.
ok for building the image if i understand .
i should create a folder and inside the folder from the terminal
i should use command FROM graylog2/server:latest then RUN wget -O /usr/share/graylog/plugin/graylog-plugin-slack-2.4.0.jar https://github.com/graylog-labs/graylog-plugin-slack/releases/download/2.4.0/graylog-plugin-slack-2.4.0.jar ?
and built it with docker build -t graylog-with-slack-plugin
thanks and i swear i’m not a dummy :joy:
yes i swear i’m a dummy I SHOULD CREATE A DOKERFILE ! :joy:
It just take me time to understand so lets go learn docker a liltle bit !
What a joy Graylog !!!
would like to know if we can add some type of two factor authentication to graylog like google authenticator ?
any possibility to archive logs to aws s3 bucket ?
thanks
Please create new topics for new questions.
