Problems in graylog about Disk Journal and Process buffer
hi everyone,
I have the version of graylog 3.2.6 and I have the following errors:
  • I only have 1 node
  • Process buffer → 65536 messages in process buffer, 100.00% utilized.
  • Output buffer → 65536 messages in output buffer, 100.00% utilized.
  • Disk Journal → 101.51%
3,704,904 unprocessed messages are currently in the journal, in 53 segments.
0 messages have been appended in the last second, 0 messages have been read in the last second.
  • Memory/Heap usage → The JVM is using 816.8MiB of 972.8MiB heap space and will not attempt to use more than 972.8M
to finish I have configured a stream and an index-set with:
Shards:
4
Replicas:
0
Field type refresh interval:
5 seconds
Index rotation strategy:
Index Size
Max index size:
1073741824 bytes (1.0GiB)
Index retention strategy:
Delete
Max number of indices:10
and graylog :
  • cpu consumption by graylog java is: 86 %
  • the machine had 4 cpu and 8 memory and jvm ->4g
  • outputbuffer_processors = 3
  • processbuffer_processors = 5
more dates:
“status” : “green”,
“timed_out” : false,
“number_of_nodes” : 1,
“number_of_data_nodes” : 1,
“active_primary_shards” : 84,
“active_shards” : 84,
“relocating_shards” : 0,
“initializing_shards” : 0,
“unassigned_shards” : 0,
“delayed_unassigned_shards” : 0,
“number_of_pending_tasks” : 0,
“number_of_in_flight_fetch” : 0,
“task_max_waiting_in_queue_millis” : 0,
“active_shards_percent_as_number” : 100.0
more dates:
“size_in_bytes” : 6708393602
memory_size_in_bytes" : 9405192,
mem" : {
“total_in_bytes” : 8345530368,
“free_in_bytes” : 3799244800,
“used_in_bytes” : 4546285568,
“free_percent” : 46,
“used_percent” : 54
“process” : {
“cpu” : {
“percent” : 0
“open_file_descriptors” : {
“min” : 2040,
“max” : 2040,
“avg” : 2040
“mem” : {
“heap_used_in_bytes” : 336385816,
“heap_max_in_bytes” : 3186360320
“threads” : 48
Many many thanks,
…your disk journal is full. What’s disk utilization look like on that box? If your disk is full, then Graylog’s gonna have a bad time.
hi,
sorry me, how can I give you the information you ask for?. What I can tell you is that I don’t have the parameters configured in graylog. Would you have to configure them?
thanks,
[image]
Hey there. Run df -h on that system. What does it say? We’re not talking about Graylog itself at this point. It’s your system’s disk.
hi ,
there are no space problems. the fs are 44% free.
regards.
hi everyone,
I have already managed to lower the journal disk, increasing the space. But now, the big question is:
How can I clean the buffer? or How can I modify the buffer so that it is not 100%? ,
  • Output buffer → 65536 messages in output buffer, 100.00% utilized. → solution ?
  • Process buffer → 65536 messages in process buffer, 100.00% utilized. → solution ?
output_batch_size 500
processbuffer_processors = 4
outputbuffer_processors = 7
input → Receive Buffer Size → 1048576 , → should i increase it?
Can you please help me ?
Many many thanks much,
he @elpedrop
you should check the elasticsearch log.
I guess you have the worker queue full as your Graylog is connecting with up to 7 connections at the same time …
Lower the outputbuffer_processor to 3 and raise the output_batch_size to 1500 this should allow your Graylog to handover the messages to elasticsearch in time.
In addition you should create a custom mapping for Elasticsearch that sets the index_refresh rate to ~30 seconds. That will give you a performance boost at all.
hi jan ,
How can I make the change in elastic of index, how is it done? dynamically? or
or in the elastisearch.yml file?
many thanks
he @elpedrop
you have multiple options for that. Once is via the custom mapping as described here:
https://docs.graylog.org/en/4.0/pages/configuration/elasticsearch.html#custom-index-mappings
but your favorite search engine will give you more options.
hi ,
sorry, it already seems to work.
Many thanks,
