Problem with Node performance
II’m Graylog newbie user. ’ve got single Node deployment (8vCPUs and 32GB RAM with local MongoDB, data and web server roles). Syslog endpoints less than 15 configured to send logs to this Node via TCP Syslog. Got some problems with Graylog Node performance
got problems displayed on the screenshot
  • OS Information: Ubuntu 24.04
  • Package Version: 7.0.3
Just checked the Node and tried to understand the reason of the problem
Any suggestion what should I check and advices to apply any optimization(s) or fixes
thx in advance for helping
Hello @anton123,
Understanding how to size the cluster appropriate to daily ingest in important, what is your daily ingest currently - you should be able to view it under System/Overview?
