Graylog cluster : high cpu on a node even if there's no active input nor processing
I noticed a strange behavior when adding a node on my graylog cluster :
graylog-server is running on this new node, which is well integrated within the other nodes of the cluster; the udp load balancer isn’t yet sending messages to it. Moreover, I disabled all inputs on this new node. But graylog-server process is still hitting near 100% of its cpu cores.
here’s my config :
  • 1 nginx udp load balancer for syslog messages
  • 4 graylog latest version nodes
  • 1 elascticsearch 5.6 + mongodb server 3.4
Thanx in advance for any clue.
you might find the reason in the Graylog server.log of the node that is going wild.
log seems fine since last start :
2018-09-27T09:36:40.865+02:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 2.4.6 [org.graylog.aws.plugin.AWSPlugin]
2018-09-27T09:36:40.875+02:00 INFO  [CmdLineTool] Loaded plugin: Elastic Beats Input 2.4.6 [org.graylog.plugins.beats.BeatsInputPlugin]
2018-09-27T09:36:40.876+02:00 INFO  [CmdLineTool] Loaded plugin: CEF Input 2.4.6 [org.graylog.plugins.cef.CEFInputPlugin]
2018-09-27T09:36:40.877+02:00 INFO  [CmdLineTool] Loaded plugin: Collector 2.4.6 [org.graylog.plugins.collector.CollectorPlugin]
2018-09-27T09:36:40.878+02:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.4.6 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2018-09-27T09:36:40.879+02:00 INFO  [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.4.6 [org.graylog.plugins.map.MapWidgetPlugin]
2018-09-27T09:36:40.880+02:00 INFO  [CmdLineTool] Loaded plugin: NetFlow Plugin 2.4.6 [org.graylog.plugins.netflow.NetFlowPlugin]
2018-09-27T09:36:40.888+02:00 INFO  [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.4.6 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2018-09-27T09:36:40.888+02:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 2.4.6 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2018-09-27T09:36:41.558+02:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms2g -Xmx2g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2018-09-27T09:36:41.848+02:00 INFO  [Version] HV000001: Hibernate Validator 5.1.3.Final
2018-09-27T09:36:44.699+02:00 INFO  [InputBufferImpl] Message journal is enabled.
2018-09-27T09:36:44.743+02:00 INFO  [NodeId] Node ID: 4b3eab03-dc2c-4167-a9a2-3013aa8ea98f
2018-09-27T09:36:44.962+02:00 INFO  [LogManager] Loading logs.
2018-09-27T09:36:45.059+02:00 INFO  [LogManager] Logs loading complete.
2018-09-27T09:36:45.059+02:00 INFO  [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2018-09-27T09:36:45.080+02:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <YieldingWaitStrategy>, running 2 parallel message handlers.
2018-09-27T09:36:45.104+02:00 INFO  [cluster] Cluster created with settings {hosts=[sonde-bdd:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2018-09-27T09:36:45.155+02:00 INFO  [cluster] No server chosen by ReadPreferenceServerSelector{readPreference=primary} from cluster description ClusterDescription{type=UNKNOWN, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=sonde-bdd:27017, type=UNKNOWN, state=CONNECTING}]}. Waiting for 30000 ms before timing out
2018-09-27T09:36:45.195+02:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:171}] to sonde-bdd:27017
2018-09-27T09:36:45.202+02:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=sonde-bdd:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[3, 4, 17]}, minWireVersion=0, maxWireVersion=5, maxDocumentSize=16777216, roundTripTimeNanos=763557}
2018-09-27T09:36:45.210+02:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:172}] to sonde-bdd:27017
2018-09-27T09:36:45.641+02:00 INFO  [AbstractJestClient] Setting server pool to a list of 1 servers: [http://10.4.1.57:9200]
2018-09-27T09:36:45.642+02:00 INFO  [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2018-09-27T09:36:45.734+02:00 INFO  [JestClientFactory] Using custom ObjectMapper instance
2018-09-27T09:36:45.734+02:00 INFO  [JestClientFactory] Node Discovery disabled...
2018-09-27T09:36:45.734+02:00 INFO  [JestClientFactory] Idle connection reaping disabled...
2018-09-27T09:36:46.011+02:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <YieldingWaitStrategy>.
2018-09-27T09:36:48.388+02:00 INFO  [RulesEngineProvider] No static rules file loaded.
2018-09-27T09:36:48.822+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /var/local/GeoLite2-City.mmdb
2018-09-27T09:36:48.834+02:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:173}] to sonde-bdd:27017
2018-09-27T09:36:48.847+02:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <YieldingWaitStrategy>.
2018-09-27T09:36:49.196+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /var/local/GeoLite2-City.mmdb
2018-09-27T09:36:49.395+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /var/local/GeoLite2-City.mmdb
2018-09-27T09:36:49.543+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /var/local/GeoLite2-City.mmdb
2018-09-27T09:36:49.716+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /var/local/GeoLite2-City.mmdb
2018-09-27T09:36:50.068+02:00 INFO  [ServerBootstrap] Graylog server 2.4.6+ceaa7e4 starting up
2018-09-27T09:36:50.068+02:00 INFO  [ServerBootstrap] JRE: Oracle Corporation 1.8.0_181 on Linux 4.15.0-20-generic
2018-09-27T09:36:50.068+02:00 INFO  [ServerBootstrap] Deployment: deb
2018-09-27T09:36:50.069+02:00 INFO  [ServerBootstrap] OS: Ubuntu 18.04.1 LTS (bionic)
2018-09-27T09:36:50.069+02:00 INFO  [ServerBootstrap] Arch: amd64
2018-09-27T09:36:50.109+02:00 INFO  [PeriodicalsService] Starting 25 periodicals ...
2018-09-27T09:36:50.110+02:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2018-09-27T09:36:50.116+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.116+02:00 INFO  [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2018-09-27T09:36:50.126+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.127+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.128+02:00 INFO  [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2018-09-27T09:36:50.130+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.132+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.IndexRetentionThread] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.132+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.IndexRotationThread] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.134+02:00 INFO  [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2018-09-27T09:36:50.135+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.VersionCheckThread] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.135+02:00 INFO  [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2018-09-27T09:36:50.137+02:00 INFO  [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2018-09-27T09:36:50.140+02:00 INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:174}] to sonde-bdd:27017
2018-09-27T09:36:50.142+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.143+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.145+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.150+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.150+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.150+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.AlarmCallbacksMigrationPeriodical] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.150+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.150+02:00 INFO  [PeriodicalsService] Not starting [org.graylog2.periodical.LdapGroupMappingMigration] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.156+02:00 INFO  [Periodicals] Starting [org.graylog2.periodical.IndexFailuresPeriodical] periodical, running forever.
2018-09-27T09:36:50.159+02:00 INFO  [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2018-09-27T09:36:50.161+02:00 INFO  [PeriodicalsService] Not starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.161+02:00 INFO  [PeriodicalsService] Not starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical. Only started on Graylog master nodes.
2018-09-27T09:36:50.188+02:00 INFO  [LookupTableService] Data Adapter otx-api-ip/5a53280a3656ae5184db21ff [@530ac3] STARTING
2018-09-27T09:36:50.190+02:00 WARN  [OTXDataAdapter] OTX API key is missing. Make sure to add the key to allow higher request limits.
2018-09-27T09:36:50.195+02:00 INFO  [LookupTableService] Data Adapter abuse-ch-ransomware-domains/5a53280a3656ae5184db21fd [@1464d747] STARTING
2018-09-27T09:36:50.207+02:00 INFO  [LookupTableService] Data Adapter whois/5a53280a3656ae5184db2202 [@ac8a9] STARTING
2018-09-27T09:36:50.209+02:00 INFO  [LookupTableService] Data Adapter whois/5a53280a3656ae5184db2202 [@ac8a9] RUNNING
2018-09-27T09:36:50.196+02:00 ERROR [LookupDataAdapter] Couldn't start data adapter <abuse-ch-ransomware-domains/5a53280a3656ae5184db21fd/@1464d747>
org.graylog.plugins.threatintel.tools.AdapterDisabledException: Abuse.ch service is disabled, not starting adapter. To enable it please go to System / Configurations.
	at org.graylog.plugins.threatintel.adapters.abusech.AbuseChRansomAdapter.doStart(AbuseChRansomAdapter.java:80) ~[?:?]
	at org.graylog2.plugin.lookup.LookupDataAdapter.startUp(LookupDataAdapter.java:59) [graylog.jar:?]
	at com.google.common.util.concurrent.AbstractIdleService$DelegateService$1.run(AbstractIdleService.java:62) [graylog.jar:?]
	at com.google.common.util.concurrent.Callables$4.run(Callables.java:122) [graylog.jar:?]
	at java.lang.Thread.run(Thread.java:748) [?:1.8.0_181]
2018-09-27T09:36:50.215+02:00 INFO  [LookupTableService] Data Adapter abuse-ch-ransomware-domains/5a53280a3656ae5184db21fd [@1464d747] RUNNING
2018-09-27T09:36:50.216+02:00 INFO  [LookupTableService] Data Adapter tor-exit-node/5a53280a3656ae5184db21fe [@21c4e6fc] STARTING
2018-09-27T09:36:50.218+02:00 INFO  [LookupTableService] Data Adapter spamhaus-drop/5a53280a3656ae5184db2200 [@3fccbf84] STARTING
2018-09-27T09:36:50.219+02:00 INFO  [LookupTableService] Data Adapter otx-api-domain/5a53280a3656ae5184db2201 [@27b70cec] STARTING
2018-09-27T09:36:50.219+02:00 WARN  [OTXDataAdapter] OTX API key is missing. Make sure to add the key to allow higher request limits.
2018-09-27T09:36:50.217+02:00 ERROR [LookupDataAdapter] Couldn't start data adapter <tor-exit-node/5a53280a3656ae5184db21fe/@21c4e6fc>
org.graylog.plugins.threatintel.tools.AdapterDisabledException: TOR service is disabled, not starting TOR exit addresses adapter. To enable it please go to System / Configurations.
	at org.graylog.plugins.threatintel.adapters.tor.TorExitNodeDataAdapter.doStart(TorExitNodeDataAdapter.java:73) ~[?:?]
2018-09-27T09:36:50.219+02:00 ERROR [LookupDataAdapter] Couldn't start data adapter <spamhaus-drop/5a53280a3656ae5184db2200/@3fccbf84>
org.graylog.plugins.threatintel.tools.AdapterDisabledException: Spamhaus service is disabled, not starting (E)DROP adapter. To enable it please go to System / Configurations.
	at org.graylog.plugins.threatintel.adapters.spamhaus.SpamhausEDROPDataAdapter.doStart(SpamhausEDROPDataAdapter.java:68) ~[?:?]
2018-09-27T09:36:50.224+02:00 INFO  [LookupTableService] Data Adapter abuse-ch-ransomware-ip/5a53280a3656ae5184db21fc [@27ce9c71] STARTING
2018-09-27T09:36:50.225+02:00 ERROR [LookupDataAdapter] Couldn't start data adapter <abuse-ch-ransomware-ip/5a53280a3656ae5184db21fc/@27ce9c71>
2018-09-27T09:36:50.228+02:00 INFO  [LookupTableService] Data Adapter tor-exit-node/5a53280a3656ae5184db21fe [@21c4e6fc] RUNNING
2018-09-27T09:36:50.230+02:00 INFO  [LookupTableService] Data Adapter spamhaus-drop/5a53280a3656ae5184db2200 [@3fccbf84] RUNNING
2018-09-27T09:36:50.237+02:00 INFO  [LookupTableService] Data Adapter otx-api-domain/5a53280a3656ae5184db2201 [@27b70cec] RUNNING
2018-09-27T09:36:50.237+02:00 INFO  [LookupTableService] Data Adapter otx-api-ip/5a53280a3656ae5184db21ff [@530ac3] RUNNING
2018-09-27T09:36:50.235+02:00 INFO  [LookupTableService] Data Adapter abuse-ch-ransomware-ip/5a53280a3656ae5184db21fc [@27ce9c71] RUNNING
2018-09-27T09:36:50.254+02:00 INFO  [LookupTableService] Cache threat-intel-uncached-adapters/5a53280a3656ae5184db21f7 [@45179183] STARTING
2018-09-27T09:36:50.254+02:00 INFO  [LookupTableService] Cache whois-cache/5a53280a3656ae5184db21f9 [@3e79bf1d] STARTING
2018-09-27T09:36:50.256+02:00 INFO  [LookupTableService] Cache threat-intel-uncached-adapters/5a53280a3656ae5184db21f7 [@45179183] RUNNING
2018-09-27T09:36:50.256+02:00 INFO  [LookupTableService] Cache otx-api-ip-cache/5a53280a3656ae5184db21f8 [@70012117] STARTING
2018-09-27T09:36:50.261+02:00 INFO  [LookupTableService] Cache otx-api-ip-cache/5a53280a3656ae5184db21f8 [@70012117] RUNNING
2018-09-27T09:36:50.261+02:00 INFO  [LookupTableService] Cache whois-cache/5a53280a3656ae5184db21f9 [@3e79bf1d] RUNNING
2018-09-27T09:36:50.261+02:00 INFO  [LookupTableService] Cache spamhaus-e-drop-cache/5a53280a3656ae5184db21fa [@1b71e1ba] STARTING
2018-09-27T09:36:50.258+02:00 INFO  [LookupTableService] Cache otx-api-domain-cache/5a53280a3656ae5184db21f6 [@58a8b76f] STARTING
2018-09-27T09:36:50.262+02:00 INFO  [LookupTableService] Cache spamhaus-e-drop-cache/5a53280a3656ae5184db21fa [@1b71e1ba] RUNNING
2018-09-27T09:36:50.262+02:00 INFO  [LookupTableService] Cache otx-api-domain-cache/5a53280a3656ae5184db21f6 [@58a8b76f] RUNNING
2018-09-27T09:36:50.271+02:00 INFO  [LookupTableService] Starting lookup table tor-exit-node-list/5a53280a3656ae5184db2204 [@492aef31] using cache threat-intel-uncached-adapters/5a53280a3656ae5184db21f7 [@45179183], data adapter tor-exit-node/5a53280a3656ae5184db21fe [@21c4e6fc]
2018-09-27T09:36:50.272+02:00 INFO  [LookupTableService] Starting lookup table whois/5a53280a3656ae5184db2205 [@6457e802] using cache whois-cache/5a53280a3656ae5184db21f9 [@3e79bf1d], data adapter whois/5a53280a3656ae5184db2202 [@ac8a9]
2018-09-27T09:36:50.272+02:00 INFO  [LookupTableService] Starting lookup table otx-api-domain/5a53280a3656ae5184db2206 [@4fadcadb] using cache otx-api-domain-cache/5a53280a3656ae5184db21f6 [@58a8b76f], data adapter otx-api-domain/5a53280a3656ae5184db2201 [@27b70cec]
2018-09-27T09:36:50.272+02:00 INFO  [LookupTableService] Starting lookup table abuse-ch-ransomware-domains/5a53280a3656ae5184db2207 [@11fb8846] using cache threat-intel-uncached-adapters/5a53280a3656ae5184db21f7 [@45179183], data adapter abuse-ch-ransomware-domains/5a53280a3656ae5184db21fd [@1464d747]
2018-09-27T09:36:50.272+02:00 INFO  [LookupTableService] Starting lookup table spamhaus-drop/5a53280a3656ae5184db2208 [@fb6ae2f] using cache spamhaus-e-drop-cache/5a53280a3656ae5184db21fa [@1b71e1ba], data adapter spamhaus-drop/5a53280a3656ae5184db2200 [@3fccbf84]
2018-09-27T09:36:50.273+02:00 INFO  [LookupTableService] Starting lookup table otx-api-ip/5a53280a3656ae5184db2209 [@547a5023] using cache otx-api-ip-cache/5a53280a3656ae5184db21f8 [@70012117], data adapter otx-api-ip/5a53280a3656ae5184db21ff [@530ac3]
2018-09-27T09:36:50.273+02:00 INFO  [LookupTableService] Starting lookup table abuse-ch-ransomware-ip/5a53280a3656ae5184db220a [@7520b365] using cache threat-intel-uncached-adapters/5a53280a3656ae5184db21f7 [@45179183], data adapter abuse-ch-ransomware-ip/5a53280a3656ae5184db21fc [@27ce9c71]
2018-09-27T09:36:50.625+02:00 INFO  [JerseyService] Enabling CORS for HTTP endpoint
2018-09-27T09:37:02.759+02:00 INFO  [NetworkListener] Started listener bound to [10.4.1.214:12900]
2018-09-27T09:37:02.761+02:00 INFO  [HttpServer] [HttpServer] Started.
2018-09-27T09:37:02.762+02:00 INFO  [JerseyService] Started REST API at <http://10.4.1.214:12900/>
2018-09-27T09:37:06.547+02:00 INFO  [NetworkListener] Started listener bound to [127.0.0.1:9000]
2018-09-27T09:37:06.547+02:00 INFO  [HttpServer] [HttpServer-1] Started.
2018-09-27T09:37:06.548+02:00 INFO  [JerseyService] Started Web Interface at <http://127.0.0.1:9000/>
2018-09-27T09:37:06.548+02:00 INFO  [ServiceManagerListener] Services are healthy
2018-09-27T09:37:06.549+02:00 INFO  [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2018-09-27T09:37:06.551+02:00 INFO  [ServerBootstrap] Services started, startup times in ms: {InputSetupService [RUNNING]=8, OutputSetupService [RUNNING]=9, ConfigurationEtagService [RUNNING]=9, BufferSynchronizerService [RUNNING]=13, JournalReader [RUNNING]=22, KafkaJournal [RUNNING]=25, PeriodicalsService [RUNNING]=55, StreamCacheService [RUNNING]=117, LookupTableService [RUNNING]=156, JerseyService [RUNNING]=16440}
2018-09-27T09:37:06.561+02:00 INFO  [ServerBootstrap] Graylog server up and running.
2018-09-27T09:37:06.610+02:00 INFO  [InputStateListener] Input [Syslog UDP/57ceacb7e40ee75636e93f05] is now STARTING
2018-09-27T09:37:06.612+02:00 INFO  [InputStateListener] Input [GELF UDP/58e4b752bab9aa05c9e4dd10] is now STARTING
2018-09-27T09:37:06.615+02:00 INFO  [InputStateListener] Input [Syslog UDP/58e4ba31bab9aa05c9e4e049] is now STARTING
2018-09-27T09:37:06.616+02:00 INFO  [InputStateListener] Input [Syslog UDP/58f9d731bab9aa05c9fb10ff] is now STARTING
2018-09-27T09:37:06.619+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/58fef44bbab9aa05c9007083] is now STARTING
2018-09-27T09:37:06.621+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/58fef572bab9aa05c90071c3] is now STARTING
2018-09-27T09:37:06.622+02:00 INFO  [InputStateListener] Input [GELF TCP/58ff3a0ebab9aa05c900ba34] is now STARTING
2018-09-27T09:37:06.623+02:00 INFO  [InputStateListener] Input [Syslog UDP/59243bee3656ae03347a15a9] is now STARTING
2018-09-27T09:37:06.625+02:00 INFO  [InputStateListener] Input [Beats/59a3ddfb3656ae188faee278] is now STARTING
2018-09-27T09:37:06.626+02:00 INFO  [InputStateListener] Input [Beats/59a026163656ae188faaf923] is now STARTING
2018-09-27T09:37:06.627+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/59c9f6d328bd740abfef05fa] is now STARTING
2018-09-27T09:37:06.629+02:00 INFO  [InputStateListener] Input [Beats/59d2252d3656ae6c891f2b62] is now STARTING
2018-09-27T09:37:06.631+02:00 INFO  [InputStateListener] Input [Beats/5a180bfc3656ae3bd815d02c] is now STARTING
2018-09-27T09:37:06.632+02:00 INFO  [InputStateListener] Input [GELF UDP/5a33e52328f8af3e408dd23e] is now STARTING
2018-09-27T09:37:06.633+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5a5de8a628f8af1b134ac131] is now STARTING
2018-09-27T09:37:06.637+02:00 INFO  [InputStateListener] Input [Beats/5a33a25628f8af3e408d8f02] is now STARTING
2018-09-27T09:37:06.638+02:00 INFO  [InputStateListener] Input [Beats/5a158fdd3656ae3bd8131e12] is now STARTING
2018-09-27T09:37:06.639+02:00 INFO  [InputStateListener] Input [Syslog UDP/5abceaf228bd740466e8e40d] is now STARTING
2018-09-27T09:37:06.641+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5adefaac1fec54166f8755b6] is now STARTING
2018-09-27T09:37:07.505+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=RAW udp 514 vers 8514, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.505+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input GELFUDPInput{title=gelf udp global, type=org.graylog2.inputs.gelf.udp.GELFUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.508+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=raw plaintext haproxy http global, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=null} should be 1048576 but is 212992.
2018-09-27T09:37:07.508+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5adefaac1fec54166f8755b6] is now RUNNING
2018-09-27T09:37:07.510+02:00 INFO  [InputStateListener] Input [GELF UDP/58e4b752bab9aa05c9e4dd10] is now RUNNING
2018-09-27T09:37:07.511+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/58fef44bbab9aa05c9007083] is now RUNNING
2018-09-27T09:37:07.521+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=syslog sam et janice global, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.522+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=cisco udp 13514 global, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.523+02:00 INFO  [InputStateListener] Input [Syslog UDP/58f9d731bab9aa05c9fb10ff] is now RUNNING
2018-09-27T09:37:07.528+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=Beats 5044 global, type=org.graylog.plugins.beats.BeatsInput, nodeId=null} should be 1048576 but is 212992.
2018-09-27T09:37:07.533+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=beats 5099 cluster recherche global, type=org.graylog.plugins.beats.BeatsInput, nodeId=null} should be 1048576 but is 212992.
2018-09-27T09:37:07.535+02:00 INFO  [InputStateListener] Input [Syslog UDP/59243bee3656ae03347a15a9] is now RUNNING
2018-09-27T09:37:07.540+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=beats 5025 zimbra global, type=org.graylog.plugins.beats.BeatsInput, nodeId=null} should be 1048576 but is 212992.
2018-09-27T09:37:07.541+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=fortinet udp RAW 11514 global, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.541+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=fortinet RAW udp 12514 global, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.545+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input GELFUDPInput{title=gelf udp 12225 zimbra nginx, type=org.graylog2.inputs.gelf.udp.GELFUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.542+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=syslog udp 10514 global, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.548+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=beats 5026 zimbra nginx global, type=org.graylog.plugins.beats.BeatsInput, nodeId=null} should be 1048576 but is 212992.
2018-09-27T09:37:07.554+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=Beats 5046 global (Tomcat), type=org.graylog.plugins.beats.BeatsInput, nodeId=null} should be 1048576 but is 212992.
2018-09-27T09:37:07.554+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input RawUDPInput{title=raw plaintext haproxy tcp global, type=org.graylog2.inputs.raw.udp.RawUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.554+02:00 INFO  [InputStateListener] Input [Beats/59a3ddfb3656ae188faee278] is now RUNNING
2018-09-27T09:37:07.549+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=switchs syslog udp 15514, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=null} should be 262144 but is 212992.
2018-09-27T09:37:07.560+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input GELFTCPInput{title=gelf tcp12203 pour apache global, type=org.graylog2.inputs.gelf.tcp.GELFTCPInput, nodeId=null} should be 1048576 but is 212992.
2018-09-27T09:37:07.561+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input SyslogUDPInput{title=Extreme-wifi 14514 syslog udp, type=org.graylog2.inputs.syslog.udp.SyslogUDPInput, nodeId=eb99cbd2-552c-4272-aae7-b305accbb2dd} should be 262144 but is 212992.
2018-09-27T09:37:07.566+02:00 WARN  [NettyTransport] receiveBufferSize (SO_RCVBUF) for input BeatsInput{title=Beats 5045 global, type=org.graylog.plugins.beats.BeatsInput, nodeId=null} should be 1048576 but is 212992.
2018-09-27T09:37:07.568+02:00 INFO  [InputStateListener] Input [Beats/5a180bfc3656ae3bd815d02c] is now RUNNING
2018-09-27T09:37:07.570+02:00 INFO  [InputStateListener] Input [Beats/5a158fdd3656ae3bd8131e12] is now RUNNING
2018-09-27T09:37:07.571+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/5a5de8a628f8af1b134ac131] is now RUNNING
2018-09-27T09:37:07.572+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/59c9f6d328bd740abfef05fa] is now RUNNING
2018-09-27T09:37:07.573+02:00 INFO  [InputStateListener] Input [GELF UDP/5a33e52328f8af3e408dd23e] is now RUNNING
2018-09-27T09:37:07.575+02:00 INFO  [InputStateListener] Input [Syslog UDP/58e4ba31bab9aa05c9e4e049] is now RUNNING
2018-09-27T09:37:07.576+02:00 INFO  [InputStateListener] Input [Beats/5a33a25628f8af3e408d8f02] is now RUNNING
2018-09-27T09:37:07.577+02:00 INFO  [InputStateListener] Input [Beats/59d2252d3656ae6c891f2b62] is now RUNNING
2018-09-27T09:37:07.578+02:00 INFO  [InputStateListener] Input [Raw/Plaintext UDP/58fef572bab9aa05c90071c3] is now RUNNING
2018-09-27T09:37:07.580+02:00 INFO  [InputStateListener] Input [Syslog UDP/5abceaf228bd740466e8e40d] is now RUNNING
2018-09-27T09:37:07.581+02:00 INFO  [InputStateListener] Input [GELF TCP/58ff3a0ebab9aa05c900ba34] is now RUNNING
2018-09-27T09:37:07.582+02:00 INFO  [InputStateListener] Input [Syslog UDP/57ceacb7e40ee75636e93f05] is now RUNNING
2018-09-27T09:37:07.584+02:00 INFO  [InputStateListener] Input [Beats/59a026163656ae188faaf923] is now RUNNING
however, i got recurrent errors like that :
2018-08-31T15:00:54.621+02:00 ERROR [AlertConditionFactory] Could not load alert condition <95f950d4-2b2b-47a1-95b5-a23f8bec08f6>, invalid configuration detected.
2018-08-31T15:00:54.621+02:00 ERROR [StreamServiceImpl] Skipping alert condition.
org.graylog2.plugin.configuration.ConfigurationException: Mandatory configuration field backlog is missing or has the wrong data type
        at org.graylog2.plugin.configuration.ConfigurationRequest.check(ConfigurationRequest.java:111) ~[graylog.jar:?]
        at org.graylog2.alerts.AlertConditionFactory.createAlertCondition(AlertConditionFactory.java:63) ~[graylog.jar:?]
        at org.graylog2.alerts.AlertServiceImpl.fromPersisted(AlertServiceImpl.java:170) ~[graylog.jar:?]
        at org.graylog2.streams.StreamServiceImpl.getAlertConditions(StreamServiceImpl.java:294) [graylog.jar:?]
        at org.graylog2.periodical.AlertScannerThread.doRun(AlertScannerThread.java:55) [graylog.jar:?]
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_181]
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_181]
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_181]
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_181]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_181]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_181]
which I think is linked to another problem.
does the Graylog node do any processing while hitting 100% or is this while doing nothing?
it is while doing nothing. The load balancer doesn’t send any log - I paused message processing on that node to be sure.
top :
30706 graylog   20   0 16,493g 1,706g  25016 S  1102 10,9   4190:02 /usr/bin/java -Xms2g -Xmx2g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -jar -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/sh+
node state from de gui :
 4b3eab03 / zabbix-ng.insa-rennes.fr In 0 / Out 0 msg/s.
The journal contains 0 unprocessed messages in 1 segment. 0 messages appended, 0 messages read in the last second.
Current lifecycle state:
    Paused
Message processing:
    Disabled
Load balancer indication:
    ALIVE
server.conf on that node :
is_master = false
password_secret = ***
root_password_sha2 = ***
rest_listen_uri = http://10.4.1.214:12900/
rest_transport_uri = http://10.4.1.214:12900/
elasticsearch_hosts = http://10.4.1.57:9200
rotation_strategy = count
retention_strategy = delete
allow_highlighting = true
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
processor_wait_strategy = yielding
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
inputbuffer_wait_strategy = yielding
mongodb_uri = mongodb://sonde-bdd/graylog2
transport_email_hostname = smtp.insa-rennes.fr
transport_email_port = 25
transport_email_use_tls = false
transport_email_auth_username = you@example.com
transport_email_auth_password = secret
transport_email_subject_prefix = [graylog2]
transport_email_from_email = cri-systeme@insa-rennes.fr
transport_email_from_name = Graylog2
transport_email_web_interface_url = http://sonde.insa-rennes.fr:9000
http_write_timeout = 20s
message_cache_spool_dir = /var/lib/graylog2-server/message-cache-spool
ldap_connection_timeout = 2000
update :
a tcpdump give alot of mongo 27017 traffic :
09:32:55.359760 IP 10.4.1.215.55466 > 10.4.1.214.12900: Flags [P.], seq 1504:1973, ack 2131, win 1444, options [nop,nop,TS val 2130363701 ecr 1646958687], length 469
09:32:55.360077 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 28806:28962, ack 142317, win 4705, options [nop,nop,TS val 2915888533 ecr 3761703252], length 156
09:32:55.360302 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 142317:142482, ack 28962, win 1452, options [nop,nop,TS val 3761703286 ecr 2915888533], length 165
09:32:55.360327 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [.], ack 142482, win 4705, options [nop,nop,TS val 2915888533 ecr 3761703286], length 0
09:32:55.360628 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 28962:29119, ack 142482, win 4705, options [nop,nop,TS val 2915888533 ecr 3761703286], length 157
09:32:55.360941 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 142482:143383, ack 29119, win 1452, options [nop,nop,TS val 3761703286 ecr 2915888533], length 901
09:32:55.361164 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 29119:29276, ack 143383, win 4705, options [nop,nop,TS val 2915888534 ecr 3761703286], length 157
09:32:55.361485 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 143383:144284, ack 29276, win 1452, options [nop,nop,TS val 3761703287 ecr 2915888534], length 901
09:32:55.361699 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 29276:29433, ack 144284, win 4705, options [nop,nop,TS val 2915888534 ecr 3761703287], length 157
09:32:55.362019 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 144284:145185, ack 29433, win 1452, options [nop,nop,TS val 3761703287 ecr 2915888534], length 901
09:32:55.362231 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 29433:29590, ack 145185, win 4705, options [nop,nop,TS val 2915888535 ecr 3761703287], length 157
09:32:55.362547 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 145185:146086, ack 29590, win 1452, options [nop,nop,TS val 3761703287 ecr 2915888535], length 901
09:32:55.362755 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 29590:29747, ack 146086, win 4705, options [nop,nop,TS val 2915888535 ecr 3761703287], length 157
09:32:55.363075 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 146086:146987, ack 29747, win 1452, options [nop,nop,TS val 3761703287 ecr 2915888535], length 901
09:32:55.363283 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 29747:29904, ack 146987, win 4705, options [nop,nop,TS val 2915888536 ecr 3761703287], length 157
09:32:55.363604 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 146987:147888, ack 29904, win 1452, options [nop,nop,TS val 3761703287 ecr 2915888536], length 901
09:32:55.363819 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 29904:30061, ack 147888, win 4705, options [nop,nop,TS val 2915888536 ecr 3761703287], length 157
09:32:55.364048 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 147888:148789, ack 30061, win 1452, options [nop,nop,TS val 3761703287 ecr 2915888536], length 901
09:32:55.364258 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 30061:30218, ack 148789, win 4705, options [nop,nop,TS val 2915888537 ecr 3761703287], length 157
09:32:55.364518 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 148789:149690, ack 30218, win 1452, options [nop,nop,TS val 3761703287 ecr 2915888537], length 901
09:32:55.364725 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 30218:30375, ack 149690, win 4705, options [nop,nop,TS val 2915888537 ecr 3761703287], length 157
09:32:55.364971 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 149690:150591, ack 30375, win 1452, options [nop,nop,TS val 3761703287 ecr 2915888537], length 901
09:32:55.365180 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 30375:30532, ack 150591, win 4705, options [nop,nop,TS val 2915888538 ecr 3761703287], length 157
09:32:55.365429 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 150591:151492, ack 30532, win 1452, options [nop,nop,TS val 3761703288 ecr 2915888538], length 901
09:32:55.365636 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 30532:30628, ack 151492, win 4705, options [nop,nop,TS val 2915888538 ecr 3761703288], length 96
09:32:55.365872 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 151492:152094, ack 30628, win 1452, options [nop,nop,TS val 3761703288 ecr 2915888538], length 602
09:32:55.366093 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 30628:30785, ack 152094, win 4705, options [nop,nop,TS val 2915888539 ecr 3761703288], length 157
09:32:55.366357 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 152094:152995, ack 30785, win 1452, options [nop,nop,TS val 3761703288 ecr 2915888539], length 901
09:32:55.366569 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 30785:30942, ack 152995, win 4705, options [nop,nop,TS val 2915888539 ecr 3761703288], length 157
09:32:55.366814 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 152995:153896, ack 30942, win 1452, options [nop,nop,TS val 3761703288 ecr 2915888539], length 901
09:32:55.367091 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 30942:31099, ack 153896, win 4705, options [nop,nop,TS val 2915888540 ecr 3761703288], length 157
09:32:55.367339 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 153896:154797, ack 31099, win 1452, options [nop,nop,TS val 3761703288 ecr 2915888540], length 901
09:32:55.367549 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 31099:31256, ack 154797, win 4705, options [nop,nop,TS val 2915888540 ecr 3761703288], length 157
09:32:55.367792 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 154797:155698, ack 31256, win 1452, options [nop,nop,TS val 3761703288 ecr 2915888540], length 901
09:32:55.368135 IP 10.4.1.214.12900 > 10.4.1.215.55466: Flags [P.], seq 2131:2595, ack 1973, win 1452, options [nop,nop,TS val 1646960022 ecr 2130363701], length 464
and then
09:32:56.110683 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 31256:31407, ack 155698, win 4705, options [nop,nop,TS val 2915889283 ecr 3761703288], length 151
09:32:56.111048 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 155698:156022, ack 31407, win 1452, options [nop,nop,TS val 3761703474 ecr 2915889283], length 324
09:32:56.111065 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [.], ack 156022, win 4705, options [nop,nop,TS val 2915889284 ecr 3761703474], length 0
09:32:56.111208 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 31407:31744, ack 156022, win 4705, options [nop,nop,TS val 2915889284 ecr 3761703474], length 337
09:32:56.111477 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 156022:156097, ack 31744, win 1452, options [nop,nop,TS val 3761703474 ecr 2915889284], length 75
09:32:56.111559 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 31744:31889, ack 156097, win 4705, options [nop,nop,TS val 2915889284 ecr 3761703474], length 145
09:32:56.111795 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 156097:156157, ack 31889, win 1452, options [nop,nop,TS val 3761703474 ecr 2915889284], length 60
09:32:56.111901 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 31889:32024, ack 156157, win 4705, options [nop,nop,TS val 2915889285 ecr 3761703474], length 135
09:32:56.112121 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 156157:156478, ack 32024, win 1452, options [nop,nop,TS val 3761703474 ecr 2915889285], length 321
09:32:56.112208 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 32024:32168, ack 156478, win 4705, options [nop,nop,TS val 2915889285 ecr 3761703474], length 144
09:32:56.112471 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 156478:156538, ack 32168, win 1452, options [nop,nop,TS val 3761703474 ecr 2915889285], length 60
09:32:56.114507 IP 10.4.1.214.40840 > 10.4.1.57.27017: Flags [P.], seq 32168:32350, ack 156538, win 4705, options [nop,nop,TS val 2915889287 ecr 3761703474], length 182
09:32:56.114810 IP 10.4.1.57.27017 > 10.4.1.214.40840: Flags [P.], seq 156538:156665, ack 32350, win 1452, options [nop,nop,TS val 3761703475 ecr 2915889287], length 127
and repeat
so, maybe it’s linked to mongodb? but why?
anyway thanx, jan for taking your time reading this post :
Keep up, the good work at graylog’s :slight_smile:
cheers
MongoDB holds the configuration and also some of the error logs - so if an error is given, you get lots of MongoDB traffic …
Do you have lots of alerts configured? If not - just drop them all and look if the error is persistent. If yes then we would need to drop the alert configuration from MongoDB after you had shutdown Graylog.
thanx, will try this and post an update though.
Thanx again.
