Problem to secure graylog
Hello
Can you help me to soluce my problem ?
I have two server in this configuration :
server A => graylog 6.3.1 / mongodb 6.0.24
server B => opensearch 2.15.0
They work good. but they are unsecured.
I want to secure them step by step.
I begun to pass my graylog in https with a no self-signed certificate.
I can connect to graylog on https://mygraylog.mydomain.fr:9000 but when I go in the menu “Search”, I have this error
"Error!
Executing search failed: SyntaxError: Unexpected token 'N', "None of th"... is not valid JSON"
On server A, curl -k http://IpserverB:9200, I have a good JSON response :
  "name" : "node-1",
  "cluster_name" : "graylog",
  "cluster_uuid" : "ngiCNCv0T96nQfxTlGCRuA",
  "version" : {
    "distribution" : "opensearch",
    "number" : "2.15.0",
    "build_type" : "deb",
    "build_hash" : "61dbcd0795c9bfe9b81e5762175414bc38bbcadf",
    "build_date" : "2024-06-20T03:27:12.329408119Z",
    "build_snapshot" : false,
    "lucene_version" : "9.10.0",
    "minimum_wire_compatibility_version" : "7.10.0",
    "minimum_index_compatibility_version" : "7.0.0"
  "tagline" : "The OpenSearch Project: https://opensearch.org/"
On my server A (graylog+mongodb), I have this warning in /var/log/graylog-server/server.log :
2025-07-11T08:29:48.820Z WARN [ProxiedResource] Failed to call API on node <fac11443-3d9d-4c65-80ed-69d3e345edb7>, cause: None of the TrustManagers trust this certificate chain. (duration: 6 ms)
Thank you.
Yann
Ok ! I have soluce my problem.
Its was my certificate file.
For Graylog, the certificat file muse have the certificat but the intermediate certificate too !
I’ve done these commands
sudo openssl pkcs12 -in /home/gray01/orgincertificate.pfx -nocerts -out /etc/graylog/ssl/graylog-key.pem -nodes
sudo openssl pkcs12 -in /home/gray01/orgincertificate.pfx -clcerts -nokeys -out /etc/graylog/ssl/graylog-cert.pem
sudo openssl x509 -in /etc/graylog/ssl/graylog-cert.pem -text -noout | grep "CA Issuers"
sudo wget http://OrganizationValidationSecureServerCA.crt -O /etc/graylog/ssl/intermediate.pem
sudo file /etc/graylog/ssl/intermediate.pem
sudo openssl x509 -in /etc/graylog/ssl/intermediate.pem -inform DER -out /etc/graylog/ssl/intermediate.pem -outform PEM
==> must be /etc/graylog/ssl/intermediate.pem: PEM certificate
sudo bash -c 'cat /etc/graylog/ssl/graylog-cert.pem /etc/graylog/ssl/intermediate.pem > /etc/graylog/ssl/graylog-fullchain.pem'
sudo chmod 640 /etc/graylog/ssl*pem
sudo chown root:graylog /etc/graylog/ssl/*pem
I have complete these lines in my /etc/graylog/server/server.conf
http_enable_tls=true
http_tls_cert_file=/etc/graylog/ssl/graylog-fullchain.pem
http_tls_key_file=/etc/graylog/ssl/graylog-key.pem
Thanks.
