Problem to query on graylog timezone
Query last 5 minutes…
Nothing found
Your search returned no results, try changing the used time range or the search query. Do you want more details? Show the Elasticsearch query.
Take a look at the documentation if you need help with the search syntax or the time range selector.
To 4 days ago it was all ok, inputs are ok but graylog is an hour early
Check the logs of your Graylog and Elasticsearch nodes.
:arrow_right: http://docs.graylog.org/en/2.4/pages/configuration/file_location.html
