I installed graylog with docker and added HttpApi node but on Node page when I click on Api Browser
it shows 2 box for username and password without any button or link to go . I tried with the latest FireFox and Chrome version and result was the same . I check the console and there are lots of error
http://172.24.0.4:9000/api/api-browser/css/fonts.css net::ERR_CONNECTION_TIMED_OUT
but my gray log address is 10.0.2.106:9000
and I dont know what this IP is and how to change that
is there any suggestion ?
Hey @alireza
That is container IP Address, you either need to make routable or Bridge your container.
Example:
graylog:
image: graylog/graylog:4.2-jre11
network_mode: bridge
dns:
- 192.168.2.15
- 192.168.2.16
environment:
- GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9000
- GRAYLOG_HTTP_EXTERNAL_URI=http://192.168.1.28:9000/
Not sure how you set you docker up, I use docker-compose. with that example above I can access my node with http://192.168.1.28:9000/
thank you for your response.
I use docker-compose as it said on graylog websit with mongodb and elasticsearch and graylog inside it . I added the network as you said mode for graylog part but it could not connect to mongodb and elasticsearch so it didnt work , I uploaded my docker-compose .
Blockquote
version: ‘2’
services:
MongoDB: mongo - Official Image | Docker Hub
mongodb:
image: mongo:5.0.13
volumes:
- mongo_data:/data/db
Elasticsearch: Install Elasticsearch with Docker | Elasticsearch Guide [7.10] | Elastic
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
volumes:
environment:
- http.host=0.0.0.0
- transport.host=localhost
- network.host=0.0.0.0
- “ES_JAVA_OPTS=-Xms512m -Xmx512m”
mem_limit: 1g
Graylog: graylog/graylog - Docker Image
graylog:
image: graylog/graylog:5.0
#network_mode: bridge
#dns:
# - 10.0.2.2
volumes:
- graylog_data:/usr/share/graylog/data
- ./graylog/config:/usr/share/graylog/data/config
environment:
- GRAYLOG_PASSWORD_SECRET=somepasswordpepper
# Password: admin
- GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
- GRAYLOG_HTTP_EXTERNAL_URI=http://10.0.2.106:9000/
#entrypoint: /usr/bin/tini -- wait-for-it elasticsearch:9200 -- /docker-entrypoint.sh
links:
- mongodb:mongo
- elasticsearch
restart: always
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 1514:1514
# Syslog UDP
- 1514:1514/udp
# GELF TCP
- 12201-12210:12201-12210
# GELF UDP
- 12201:12201/udp
# Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_data:
driver: local
Blockquote
Hey @alireza
Not sure if you got it right, looks like to commented out the network, the bridge will aloow network access alos, depned on what you wan to do.
Example:
version: '2'
services:
mongodb:
image: mongo:4
volumes:
elasticsearch:
volumes:
environment:
- http.host=0.0.0.0
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
dns:
- 192.168.2.15
- 192.168.2.16
volumes:
- graylog_bin:/usr/share/graylog/bin
environment:
# Container time Zone
- TZ=America/Chicago
- GRAYLOG_PASSWORD_SECRET=pJodBpiuu2XLTZuyb2YW9eHiKLTifjy7cLpeWIjWW2nonDhN
- GRAYLOG_ROOT_PASSWORD_SHA2=ef92b778c06659911881f383d4473e94f
- GRAYLOG_ROOT_TIMEZONE=America/Chicago
Here is some example for a different configuration if you want.
