Problem by Update 3.0 -> 3.1
Hey,
we have a Problem by updating from 3.0 to 3.1.
I executed following commands:
wget https://packages.graylog2.org/repo/packages/graylog-3.1-repository_latest.deb
sudo dpkg -i graylog-3.1-repository_latest.deb
sudo apt-get update
sudo apt-get install graylog-server
sudo systemctl restart graylog-server.service
But the service is still stopped and the Web-App shows:
Graylog is currently not reachable…
Logs:
2019-08-26T09:47:39.313+02:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 3.1.0 [org.graylog.aws.AWSPlugin]
2019-08-26T09:47:39.315+02:00 INFO  [CmdLineTool] Loaded plugin: Collector 3.1.0 [org.graylog.plugins.collector.CollectorPlugin]
2019-08-26T09:47:39.316+02:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise 3.0.2 [org.graylog.plugins.enterprise.EnterprisePlugin]
2019-08-26T09:47:39.316+02:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 3.1.0 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2019-08-26T09:47:39.533+02:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2019-08-26T09:47:39.688+02:00 INFO  [Version] HV000001: Hibernate Validator 5.1.3.Final
2019-08-26T09:47:41.593+02:00 INFO  [InputBufferImpl] Message journal is enabled.
2019-08-26T09:47:41.611+02:00 INFO  [NodeId] Node ID: 5712da8b-4366-45c8-b8fb-8d36f5c79bcd
2019-08-26T09:47:41.763+02:00 INFO  [LogManager] Loading logs.
2019-08-26T09:47:41.861+02:00 WARN  [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000000007187639.index, deleting and rebuilding index...
2019-08-26T09:47:41.983+02:00 INFO  [LogManager] Logs loading complete.
2019-08-26T09:47:41.985+02:00 INFO  [KafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2019-08-26T09:47:42.019+02:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2019-08-26T09:47:42.072+02:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2019-08-26T09:47:42.103+02:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:33}] to localhost:27017
2019-08-26T09:47:42.111+02:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 9]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=7837521}
2019-08-26T09:47:42.124+02:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:34}] to localhost:27017
2019-08-26T09:47:42.363+02:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2019-08-26T09:47:42.576+02:00 INFO  [AbstractJestClient] Setting server pool to a list of 1 servers: [http://127.0.0.1:9200]
2019-08-26T09:47:42.577+02:00 INFO  [JestClientFactory] Using multi thread/connection supporting pooling connection manager
2019-08-26T09:47:42.643+02:00 INFO  [JestClientFactory] Using custom ObjectMapper instance
2019-08-26T09:47:42.643+02:00 INFO  [JestClientFactory] Node Discovery disabled...
2019-08-26T09:47:42.644+02:00 INFO  [JestClientFactory] Idle connection reaping disabled...
2019-08-26T09:47:42.876+02:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2019-08-26T09:47:43.059+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-08-26T09:47:43.069+02:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2019-08-26T09:47:43.082+02:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:35}] to localhost:27017
2019-08-26T09:47:43.134+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-08-26T09:47:43.178+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-08-26T09:47:43.221+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-08-26T09:47:43.256+02:00 WARN  [GeoIpResolverEngine] GeoIP database file does not exist: /etc/graylog/server/GeoLite2-City.mmdb
2019-08-26T09:47:43.277+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.304+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.305+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.312+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.319+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.323+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.324+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.448+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.449+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.461+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.476+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.478+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.630+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.631+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.633+02:00 ERROR [Permissions] Error adding permissions for plugin: org.graylog.plugins.enterprise.search.rest.EnterpriseSearchRestPermissions
2019-08-26T09:47:43.650+02:00 ERROR [CmdLineTool] Guice error (more detail on log level debug): Error injecting constructor, java.lang.IllegalArgumentException: Duplicate permission found. Permission "Permission{permission=view:create, description=Create new view}" already exists!
2019-08-26T09:47:43.651+02:00 ERROR [CmdLineTool] Guice error (more detail on log level debug): Error injecting constructor, java.lang.IllegalArgumentException: Duplicate permission found. Permission "Permission{permission=view:create, description=Create new view}" already exists!
I have kept the configuration file
you need to upgrade all installed Graylog Plugins.
http://docs.graylog.org/en/3.1/pages/installation/operating_system_packages.html#update-to-latest-version
