Today i update my Graylog appliance to 2.3.1 using graylog_latest.deb file. Post update i initiated the reconfigure command, then finally it throws me an error message.
Then i tried to restarted the graylog services and now the web application is taking me to the below shown image.
I wonder where i made a mistake while performing update. I have also attached the error message below.
Requesting your input on this to solve this issue, i am totally new to Graylog and its components.
Error while re-configuring:
Error executing action `run` on resource 'ruby_block[add node to server list ]'
Errno::ECONNREFUSED
Connection refused - connect(2) for "127.0.0.1" port 4001
Cookbook Trace:
/opt/graylog/embedded/cookbooks/graylog/libraries/registry.rb:17:in `set_mas ter'
/opt/graylog/embedded/cookbooks/graylog/recipes/graylog-server.rb:86:in `blo ck (2 levels) in from_file'
Resource Declaration:
# In /opt/graylog/embedded/cookbooks/graylog/recipes/graylog-server.rb
84: ruby_block "add node to server list" do
85: block do
86: $registry.set_master
87: $registry.add_gl_server(node['ipaddress'])
88: $registry.add_es_node(node['ipaddress'])
89: end
90: retries 15
91: end
Compiled Resource:
# Declared in /opt/graylog/embedded/cookbooks/graylog/recipes/graylog-server .rb:84:in `from_file'
ruby_block("add node to server list") do
action [:run]
retries 15
retry_delay 2
default_guard_interpreter :default
block_name "add node to server list"
declared_type :ruby_block
cookbook_name :graylog
recipe_name "graylog-server"
block #<Proc:0x00000002bbb938@/opt/graylog/embedded/cookbooks/graylog/reci pes/graylog-server.rb:85>
Recipe: graylog::elasticsearch
* service[elasticsearch] action restart
- restart service service[elasticsearch]
Recipe: graylog::graylog-server
* service[graylog-server] action restart
- restart service service[graylog-server]
Running handlers:
[2017-09-13T20:27:09+05:30] ERROR: Running exception handlers
Running handlers complete
[2017-09-13T20:27:09+05:30] ERROR: Exception handlers complete
Chef Client failed. 16 resources updated in 03 minutes 02 seconds
[2017-09-13T20:27:09+05:30] FATAL: Stacktrace dumped to /opt/graylog/embedded/co okbooks/cache/chef-stacktrace.out
[2017-09-13T20:27:09+05:30] FATAL: Please provide the contents of the stacktrace .out file if you file a bug report
[2017-09-13T20:27:09+05:30] ERROR: ruby_block[add node to server list] (graylog: :graylog-server line 84) had an error: Errno::ECONNREFUSED: Connection refused - connect(2) for "127.0.0.1" port 4001
[2017-09-13T20:27:09+05:30] FATAL: Chef::Exceptions::ChildConvergeError: Chef ru n process exited unsuccessfully (exit code 1)
Web page:
**Stack tracer dump:**
Generated at 2017-09-13 20:27:09 +0530
Errno::ECONNREFUSED: ruby_block[add node to server list] (graylog::graylog-server line 84) had an error: Errno::ECONNREFUSED: Connection refused - connect(2) for "127.0.0.1" port 4001
/opt/graylog/embedded/lib/ruby/2.1.0/net/http.rb:879:in `initialize'
/opt/graylog/embedded/lib/ruby/2.1.0/net/http.rb:879:in `open'
/opt/graylog/embedded/lib/ruby/2.1.0/net/http.rb:879:in `block in connect'
/opt/graylog/embedded/lib/ruby/2.1.0/timeout.rb:75:in `timeout'
/opt/graylog/embedded/lib/ruby/2.1.0/net/http.rb:878:in `connect'
/opt/graylog/embedded/lib/ruby/2.1.0/net/http.rb:863:in `do_start'
/opt/graylog/embedded/lib/ruby/2.1.0/net/http.rb:852:in `start'
/opt/graylog/embedded/lib/ruby/2.1.0/net/http.rb:1375:in `request'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/etcd-0.3.0/lib/etcd/client.rb:111:in `api_execute'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/etcd-0.3.0/lib/etcd/keys.rb:39:in `set'
/opt/graylog/embedded/cookbooks/graylog/libraries/registry.rb:17:in `set_master'
/opt/graylog/embedded/cookbooks/graylog/recipes/graylog-server.rb:86:in `block (2 levels) in from_file'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/provider/ruby_block.rb:35:in `call'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/provider/ruby_block.rb:35:in `block in action_run'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/mixin/why_run.rb:52:in `call'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/mixin/why_run.rb:52:in `add_action'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/provider.rb:175:in `converge_by'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/provider/ruby_block.rb:34:in `action_run'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/provider.rb:144:in `run_action'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/resource.rb:596:in `run_action'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/runner.rb:74:in `run_action'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/runner.rb:106:in `block (2 levels) in converge'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/runner.rb:106:in `each'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/runner.rb:106:in `block in converge'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/resource_collection/resource_list.rb:83:in `block in execute_each_resource'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/resource_collection/stepable_iterator.rb:116:in `call'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/resource_collection/stepable_iterator.rb:116:in `call_iterator_block'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/resource_collection/stepable_iterator.rb:85:in `step'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/resource_collection/stepable_iterator.rb:104:in `iterate'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/resource_collection/stepable_iterator.rb:55:in `each_with_index'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/resource_collection/resource_list.rb:81:in `execute_each_resource'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/runner.rb:105:in `converge'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/client.rb:658:in `block in converge'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/client.rb:653:in `catch'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/client.rb:653:in `converge'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/client.rb:692:in `converge_and_save'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/client.rb:271:in `run'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application.rb:261:in `block in fork_chef_client'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application.rb:249:in `fork'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application.rb:249:in `fork_chef_client'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application.rb:215:in `block in run_chef_client'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/local_mode.rb:44:in `with_server_connectivity'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application.rb:203:in `run_chef_client'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application/solo.rb:286:in `block in interval_run_chef_client'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application/solo.rb:275:in `loop'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application/solo.rb:275:in `interval_run_chef_client'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application/solo.rb:253:in `run_application'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/lib/chef/application.rb:58:in `run'
/opt/graylog/embedded/lib/ruby/gems/2.1.0/gems/chef-12.6.0/bin/chef-solo:25:in `<top (required)>'
/opt/graylog/embedded/bin/chef-solo:23:in `load'
/opt/graylog/embedded/bin/chef-solo:23:in `<main>'
Thank you
Ashwath Kumar
