I developped a plugin which is using a configuration section embedding 2 parameters: graylog endpoint and service token.
i would like to retrieve those two values from a web page of my plugin.
However, I have no idea how to make it.
Does anyone know how communication between webpages and java classes works ?
Here is my code concerning the configuration part:
Settings.java
package com.example.graylog;
import com.fasterxml.jackson.annotation.JsonAutoDetect;
import com.fasterxml.jackson.annotation.JsonCreator;
import com.fasterxml.jackson.annotation.JsonProperty;
import com.google.auto.value.AutoValue;
import javax.annotation.Nullable;
import static org.graylog2.plugin.streams.Stream.DEFAULT_STREAM_ID;
* This is the general configuration of the plugin (see System/Configurations)
* It is probably linked to the IHM, just by the configuration in the web index.jsx.
@JsonAutoDetect
@AutoValue
public abstract class Settings {
@JsonProperty("graylog_endpoint")
public abstract String accessGraylogEndpoint();
@JsonProperty("example_service_token")
public abstract String accessexampleServiceToken();
@JsonCreator
public static Settings create(
@JsonProperty("graylog_endpoint") String graylog_endpoint,
@JsonProperty("example_service_token") String example_service_token){
return builder()
.accessGraylogEndpoint(graylog_endpoint)
.accessexampleServiceToken(example_service_token)
.build();
public static Settings createDefault() {
return builder()
.accessGraylogEndpoint("https://127.0.0.1:9000")
.accessexampleServiceToken("XXX")
.build();
public static Builder builder() {
return new AutoValue_Settings.Builder();
public abstract Builder toBuilder();
@AutoValue.Builder
public abstract static class Builder {
public abstract Builder accessGraylogEndpoint(String accessGraylogEndpoint);
public abstract Builder accessexampleServiceToken(String accessexampleServiceToken);
public abstract Settings build();
settings.jsx
import React, { useState } from 'react';
import { useStore } from 'stores/connect';
import { StreamsStore } from 'views/stores/StreamsStore';
import { defaultCompare } from 'logic/DefaultCompare'
// TODO remove the ref and use property show when migrating to graylog >= 5.1
import { BootstrapModalForm, Modal, Button, Input } from 'components/bootstrap';
import IfPermitted from 'components/common/IfPermitted';
import Select from 'components/common/Select';
import Spinner from 'components/common/Spinner';
const DEFAULT_CONFIG = {
graylog_endpoint: 'https://127.0.0.1:9000',
Example_service_token: 'XXX',
const _formatOption = (key, value) => {
return { value: value, label: key };
const _displayOptionalConfigurationValue = (value) => {
if (!value) {
return '[not set]';
return value;
const Settings = ({ config = DEFAULT_CONFIG, updateConfig }) => {
const [nextConfiguration, setNextConfiguration] = useState(config);
const [showModal, setShowModal] = useState(false);
const { streams: streamList = [] } = useStore(StreamsStore);
const _openModal = () => {
setShowModal(true);
const _closeModal = () => {
setShowModal(false);
/* TODO is this necessary?
useEffect(() => {
setNextConfiguration({ ...config });
}, [config]);
const _saveConfiguration = () => {
updateConfig(nextConfiguration).then(() => {
_closeModal();
const _resetConfiguration = () => {
setNextConfiguration(config);
_closeModal()
const _updateConfigurationField = (field, value) => {
const newConfiguration = {...nextConfiguration};
newConfiguration[field] = value;
setNextConfiguration(newConfiguration);
const _onUpdate = (field) => {
return e => {
_updateConfigurationField(field, e.target.value);
if (!streamList) {
return <Spinner />;
const formattedStreams = streamList
.map(stream => _formatOption(stream.title, stream.id))
.sort((s1, s2) => defaultCompare(s1.label.toLowerCase(), s2.label.toLowerCase()));
const saveButtonClass = "Button-sc-e4msts-0 eNbEkd btn btn-success";
return (
<div>
<h3>Example Configuration</h3>
<p>
Example needs two parameters:
Graylog endpoint : The SIEM endpoint for API requesting
Example service token: A graylog service token for API authentication
</p>
<dl className="deflist">
<dt>Graylog endpoint: </dt>
<dd>
{_displayOptionalConfigurationValue(config.graylog_endpoint)}
</dd>
</dl>
<dt>Example service token: </dt>
<dd>
{_displayOptionalConfigurationValue(config.Example_service_token)}
</dd>
</dl>
<IfPermitted permissions="clusterconfigentry:edit">
<Button bsStyle="info" bsSize="xs" onClick={_openModal}>
Edit configuration
</Button>
</IfPermitted>
<Modal show={showModal} onHide={_closeModal}>
<Modal.Header closeButton>
<Modal.Title>Update Example Configuration</Modal.Title>
</Modal.Header>
<Modal.Body>
<fieldset>
<Input
id="graylog_endpoint"
type="text"
label="Graylog endpoint"
name="graylog_endpoint"
help="Graylog endpoint for API requesting."
value={nextConfiguration.graylog_endpoint}
onChange={_onUpdate('graylog_endpoint')}
<Input
id="Example_service_token"
type="text"
label="Example service token"
name="Example_service_token"
help="Example service token for API authentication."
value={nextConfiguration.Example_service_token}
onChange={_onUpdate('Example_service_token')}
</fieldset>
</Modal.Body>
<Modal.Footer>
<Button onClick={_resetConfiguration}>
Close
</Button>
<Button className={saveButtonClass} onClick={_saveConfiguration}>
Save Changes
</Button>
</Modal.Footer>
</Modal>
</div>
export default Settings;
index.jsx
import packageJson from '../../package.json';
import { PluginManifest, PluginStore } from 'graylog-web-plugin/plugin';
import SamplePage from 'pages/SamplePage';
import Settings from "./components/settings";
const metadata = {
PluginStore.register(new PluginManifest(metadata, {
/* This is the place where you define which entities you are providing to the web interface.
Right now you can add routes and navigation elements to it. */
systemConfigurations: [
component: Settings,
configType: 'com.example.graylog.Settings',
routes: [
{path: '/example', component: SamplePage},
navigation: [
path: '/example', description: 'Example'
