Pipeline with regex value
Hello all,
I’m a new French user on Graylog, and I have a question with pipeline and regex value :
I receive specific logs that contain a public IP address in the message. I have to create an aggregation with an extractor and a search with a regular expression to create a “top 10”. I’d like to use the map widget for see where its IP addresses are located in the world. I have read the process to use GeoIP, but I block at the final step : pipeline creation.
  • OS Information: Debian 11.0.14
  • Package Version: Graylog 4.2.6+0210617
  • Service logs, configurations, and environment variables: Syslog
I need help ^^
How to create this pipeline with a regex search? Below is what I would like to achieve :
rule “GeoIP:zimbra_auth_failure”
<my regex search which extracts the IP address in the field “message”>
let geo = lookup(“geoip”, to_string($message.XXXXXXX));
set_field(“src_ip_geo_location”, geo[“coordinates”]);
set_field(“src_ip_geo_country”, geo[“country”].iso_code);
set_field(“src_ip_geo_city”, geo[“city”].names.en);
Thank’s for all :slight_smile:
Hello && Welcome @FloNcy
I might be able to help
So what do you want to place here for you field or regex?
Perhaps something like this?
hope that helps
Thank’s for your reply :slight_smile:
I’d like add geoip coordinates like this instruction :
But instead of the “src_ip” field, I’d like to “extract” a value in the “message” field.
In practice: I receive messages from my mail server, and some message warns me that an IP has tried to authenticate but did not succeed (intrusion attempt).
The form of the “message” field :
warning: unknown[X.X.X.X]: SASL LOGIN authentication failed: authentication failure
My rule is :
rule "GeoIP lookup: zimbra_auth_failure"
  regex("^warning\\:\\sunknown\\[(.+?)\\]\\:\\sSASL\\sLOGIN\\sauthentication\\sfailed\\:\\sauthentication\\sfailure$", to_string($message.message)).matches == true
  let result = regex("^warning\\:\\sunknown\\[(.+?)\\]\\:\\sSASL\\sLOGIN\\sauthentication\\sfailed\\:\\sauthentication\\sfailure$", to_string($message.message));
  let geo = lookup("geoip", result["0"]);
  set_field("src_ip_geo_location", geo["coordinates"]);
  set_field("src_ip_geo_country", geo["country"].iso_code);
  set_field("src_ip_geo_city", geo["city"].names.en);
But the rule doesn’t match !
Perhaps have the regex on INPUT and create a new field. Then run GeoIP as shown in the documentation.
You actually going beyond my limits, @tmacgbay might have a better suggestion.
Hello all,
Error on my part: the regex was bad…
Since then this rule works well.
Thank’s for your help :slight_smile:
Could you post the corrected rule/regex so anyone searching for Zimbra Auth finds it? :slight_smile:
Nice…
If you could show/post what was the correct regex for this that would be great, it may help others.
Hello All :slight_smile:
The correct rule/regex is the one in my post. I had pasted the corrected one but I hadn’t written it like that in my Graylog…
And @tmacgbay yes it is for Zimbra :slight_smile:
Thank’s all and have a good week-end !
