Pipeline - Split and Extract
Hi there,
i’m stuggeling with one of my input.
I’m getting the logs in this format, semicolons are everytime the same amount:
2018-02-08;13:19:44.489;INFORMATION;;;;2288;ReadPolicy: Configuration value read from INI file: StreamingExclusionList+=<!ctx_roamingappdata!\Microsoft\SystemCertificates>
Now i would like to extract all values between the semicolons in seperate field, but i dont know how i should use the split function corectly
I tried: split(".*",";");
Thanks and regards, Raphael
What would you expect as a result of that function invocation?
If the message has the same schema every time, you could use a Grok pattern to split it into the desired fields.
I would like to split every part of that line into an seperate field (seperated by the semicolon)
Havent worked with GROK yet :frowning:
And what would the respective field name be for each field?
Date,Time,Type,Name, Domain,User,ID,Action,Message something like that
And how would you assign these field names and values without a proper mapping?
That mapping could be done (implicitly) via Grok patterns or a regular expression with named groups.
