Pipeline rules performance considerations
I am wondering about some possible performance considerations/recommendations for pipeline rules. I am running some rules with roughly 20,000 events/sec and it could really make a difference.
For example:
Is there a performance impact when making the code readable by adding more lines instead of compact one_line shots?
I mean, is something like:
set_field(“fieldname”, to_long($message.field1) * to_long($message.field2) + 3)
faster than:
let value = to_long($message.field1);
let value2 = to_long($message.field2);
let value3 = value  * value2 + 3;
set_field(“fieldname”, value3);
Or, when setting the values for several fields in a pipeline rule, is it faster to call set_field for each one of the fields? or, is it better to create a map with the values and field names and using set_fields to write them in a single operation?
Some mention of this in the documentation would be great.
Thanks!
You have many metrics too observe pipelines performances.
You should try all solutions and check metrics to see which is the faster.
