Pipeline performance optimization and metrics
Instead of attempting to upgrade my 5.x server I created a new 6.0 server and I’m going through and reworking my pipelines and rules now that I’m a bit more familiar with Graylog. I’m also working on learning the rule wizard and it’s differences.
I have a CSV message where the field number and order vary depending on the field values so I can’t use the CSV extractor. Split also caused some problems because it would skip empty fields. My 5.x pipeline splits out fields individually and adds the appropriately converted field. Each time a branching field is reached, I create a temp field containing the remainder of the CSV line. The next stage in the pipeline then applies the appropriate rule based on the branching field.
I’ve started converting this to a grok pattern and have the first stage working, but now I’m not sure of the best way to go from there. Should I continue the practice of saving the remainder of the line as a temp field? Do I create a grok pattern that builds on the initial grok pattern similar to URIHOST? Or something else entirely?
Should grok pattern extraction rules be configured to use the grok pattern in the when clause? I assume this would result in it being evaluated twice and therefore not a good idea.
I know that I want my expensive operations to run on as few messages as possible, but I’m also not sure about my stream sorting. Should I use the stream rules to group messages by device type and then a pipeline to sort that by message type into separate streams? I’m not sure what the performance difference is between stream rules and pipeline when clauses.
Does Graylog have the ability to show the time and resources taken by each action? That way I could see the effect of each change and determine if it was an improvement or not. I’d like to get a handle on how to best use Graylog while I’m still working on volumes small enough to make mistakes. :slight_smile:
Hi, linking this post: Stream Rules for Routing vs. Routing via Pipeline (Rule). Sadly no one answered it…
As far as I know there’s no tool to measure which way of doing things is faster, the only thing that comes to mind is comparing which approach puts the least amount of strain on your server (comparing RAM, CPU usage).
As always the best approach is to have the least amount of operations being done per message but sometimes this is just not possible, as to whether pipelines are faster than stream rules? - I think it’s comparable, like I said, comparing load is the only thing you can do.
It does seem like there’s very little regarding metrics and performance optimization done regarding Graylog, which is unfortunate. I did find some metrics regarding stream rules but because they use a UUID which isn’t displayed anywhere it’s impossible to determine which rule is providing which metric.
I can create all kinds of performance dashboards for my own logs so I’m really surprised that there’s not anything included in Graylog for it’s performance. Especially when your choices can make sure a difference once you scale up to enterprise log levels.
