Pipeline Rule with quotation mark
in a GELF message which reads like this:
C63C28C45C67FE7-0000000000000017 QuittungsID: DWFENTW-f40c7bc2-b0bb-zzzf-ba6b-399591671e09, DruckauftragID: ZHP-ENTW-729abcb1-6ea0-4b00-fffz-828eb1b1bf8c-1, Message received from Rest-Consumer : {"HEADER":{"ERSTELLUNGS_ZEITPUNKT":"2023-03-10T10:38:31.000036+01:00","SCHNITTSTELLE":"DokumentQuittung","VERSION":1,"HERKUNFT":"DWF","AKTION":"","ORDNUNGSBEGRIFF_TYP":"QuittungsId","ORDNUNGSBEGRIFF":"DWFENTW-f40c7bc2-b0bb-48a8-ba6b-399591671e09","AUSLOESENDER_USER":"effe","AUSLOESENDE_ANWENDUNG":"Documendomm Workflow","UMGEBUNG":"ENTW"},"QUITTUNG":{"STATUS":"OK","STATUS_CODE":4001,"MESSAGE":"Dokument archiviert","ORDNUNGSBEGRIFF_TYP":"DruckauftragID","ORDNUNGSBEGRIFF":"ZHR-ENTW-729abcb1-6ea0-4b00-88a1-828eb1b1bf8c-1","ARCDOCID":"df4ba21da4f45673f9e8c711","CONTENT_REPOSITORY":"CB","AUFTRAG_HERKUNFT":"ZRP"}}
the field StatusCode (4001) should be extracted with a regex expression:
        let m4 = regex(".*\"STATUS_CODE\":([4][0-9]{3}).*", to_string($message.message), ["statusCode"]);
        set_fields(m4);
But this does not work. How does this regex needs to look like?
Thanks in advance.
Dietmar Schurr
OS Information: openSuse 12.4
Graylog Version: 4.3.12
your : needs to be double escaped
Characters that need to be escaped:
Also you may want
 set_fields(m4["0"]);
Thank you very much.
Suddenly, if we use full_message instead of message it works!
Regards,
Dietmar
