I have pre-normalized json-formatted logs that I’m trying ingest into Graylog. I have to use the pipeline to process the logs because that’s the only way I can do the right thing based on the pod/namespace/image that generated the log.
The problem is that when I use the standard parse_json(), to_map(), set_fields() pipeline pattern on this message I have exceptions in the log. Further investigation suggests that the reason for those exceptions may be that to_map() is generating incorrect structured data.
More generally though, I’d also like any best practices for how to take any pre-normalized json log message and extract it to the log – but only when conditions from other fields are met.
OS Information: Kubernetes
Package Version: graylog/graylog:4.2.3-1
An overview of the logs generated by graylog when set_fields() is called:
$ kubectl logs -l helm.sh/chart=graylog-2.1.2 | grep '^{.*}' | jq -rs '.[] | select(.level == "ERROR") | { message, thrownName: .thrown.name, thrownMessage: .thrown.message }'
"message": "Caught exception during bulk indexing: java.lang.ClassCastException: Cannot cast java.util.LinkedHashMap to java.lang.String, retrying (attempt #1).",
"thrownName": null,
"thrownMessage": null
"message": "Couldn't bulk index 65 messages.",
"thrownName": "java.util.concurrent.ExecutionException",
"thrownMessage": "java.lang.ClassCastException: Cannot cast java.util.LinkedHashMap to java.lang.String"
"message": "Unable to flush message buffer",
"thrownName": "java.lang.RuntimeException",
"thrownMessage": "java.util.concurrent.ExecutionException: java.lang.ClassCastException: Cannot cast java.util.LinkedHashMap to java.lang.String"
"thrownName": null,
"message": "Couldn't bulk index 15 messages.",
The rule:
rule "extract pre-normalized ECS"
has_field("message")
AND has_field("container_image_name")
AND contains(to_string($message.container_image_name), "nginx")
//AND regex("\"ecs\": \\{ \"version\":", to_string($message.message)).matches == true
AND contains(to_string($message.message), "\"ecs\":")
set_field("prenormalized", "true");
let json = parse_json(to_string($message.message));
let map = to_map(json);
set_field("prenormalized_debug_json", to_string(json));
set_field("prenormalized_debug_map", to_string(map));
// set_fields(map); // if uncommented begets the errors above
example of prenormalized_debug_json:
{"timestamp":"2022-05-12T14:35:03+00:00","ecs":{"version":"8.1.0"},"http":{"request":{"bytes":2172,"line":"GET /graylog/api/ HTTP/1.1","method":"GET","referrer":"https://bdb-dev-sci-proxy-1.cisco.com/graylog/system/index_sets/622a335d133685485b0202ea","remote_user":"","time":"0.007"},"response":{"bytes":520,"status_code":200}},"source":{"ip":"10.244.177.0"},"user_agent":{"original":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.54 Safari/537.36"}}
example of prenormalized_debug_map:
{timestamp=2022-05-12T14:35:03+00:00, ecs={version=8.1.0}, http={request={bytes=2172, line=GET /graylog/api/ HTTP/1.1, method=GET, referrer=https://bdb-dev-sci-proxy-1.cisco.com/graylog/system/index_sets/622a335d133685485b0202ea, remote_user=, time=0.007}, response={bytes=520, status_code=200}}, source={ip=10.244.177.0}, user_agent={original=Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.54 Safari/537.36}}
I’ve narrowed it down to the act of setting the fields and shown that the map being used to set the fields seems to not look right. I suspect the java.util.concurrent.ExecutionException: java.lang.ClassCastException: Cannot cast java.util.LinkedHashMap to java.lang.String is related to the unexpected content seen in prenormalized_debug_map.
Please let me know if I’m doing this correctly or if this is a bug or unimplemented feature in the underlying system. I’d also appreciate any workarounds or other suggestions.
Thank you!
