Pipeline parsing logs
I’ve logs with this nomenclature :
hostname field1=value field2=01 field3=“value” etc.
For events from the same source, the order and the number of fields vary: several dozen layouts. It’s therefore not possible to do this with the extractors (the combinations (grok | grok) do not return all the fields in all cases, and this becomes unmanageable).
As the events all have the same beginning (hostname without k / v) then only k / v with the only variant: with or without quotes for the values, I told myself that it was possible to parse these events from a pipeline .
However, today I only replace prefixes, I don’t see how to perform this normalization action with the pipeline.
I wish to have :
  • For the first field: hostname: value
  • For the others: retrieve K and V as with an extractor but automatically for all the fields as we have the same syntax except quotes.
Can you help me ?
EDIT:
I create a pipeline “A” with 1 rules:
rule "KV parsing"
    has_field("kv")
    set_fields(
                fields:
                        key_value(
                            trim_value_chars: "\""
And I associate the pipeline to the stream which match log gl2_source_input.
I’ve logs in the stream, but nothing “enter” in the pipeline.
EDIT 2:
I’ve update the rule with:
rule "KV parsing"
    has_field("message")
    set_fields(
                fields:
                        key_value(
But I’ve “Throughput = 0 msg/s”. I’ve my stream that receive event connected to the pipeline. The pipeline have this rules and this rules in the simulator works.
I don’t see what I forget.
On the simulator with raw string copy/paste to message field of an event, it’s OK, i’ve only:
Mutated fields
timestamp
    2020-05-15T21:51:30.132Z
    1589550878
Is it normal ?
I change the processing order:
|1|AWS Instance Name Lookup|active|
|2|Message Filter Chain|active|
|3|Pipeline Processor|active|
|4|GeoIP Resolver|active|
Now, I see “Throughput: 288 msg/s”
But I do not see any new logs in stream with the parsing fields results :frowning:
I’ve lost message in the stream :frowning:
I roll back
he @celine
you would need to route the messages with the processing pipeline into the streams.
Create a last stage where you place with the route_to_stream functions the messages into the streams where they should go.
Hi @jan
So I do this ?:
rule "KV parsing"
    set_fields(
                fields:
                        key_value(
    route_to_stream(id:“STREAM ID”, remove_from_default:true);
Or I do create a new stage dedicated to route ? If yes, what should i put in the when condition? Just check that one of the fields from the previous internship is present?
Thanks for your time
he @celine
you can do it exactly this way.
But you could also create a new stage and decide based on now given fields where this should be routed to.
So you could have a messages from application A that should go in stream_a and you have messages from application B that should go in stream_b and the when rule would be similar to:
   has_field("application") AND
   to_string($message.application) == "A"
  route_to_stream(id: "stream id for stream_a", remove_from_default:true);
this way you are super flexibel in the design of your streams.
hi @jan
I don’t understand where is my error. I explain all of this flow :
  • I’ve an input with ID “A_INPUT”, a stream with id “A_STREAM”.
  • In my stream, I’ve configured a rule with “all logs incoming by ‘A_INPUT’ are redirected to this stream”.
  • I show the “A_INPUT” logs go to this stream.
  • I create a pipeline with ID “A_PIPELINE”. In this pipeline, I’ve a stage 0.
  • I connect this pipeline to the “A_STREAM”.
  • I create a rule with ID “A_RULE”.
This rule contains this code :
rule "A_RULE"
    set_fields(
                fields:
                        key_value(
  • I associate the “A_RULE” to the “Stage 0” of “A_PIPELINE”.
I’ve this processing order :
|2|Pipeline Processor|active|
|3|Message Filter Chain|active|
I show Current throughput 0 msg/s on the pipeline details and on the stage 0 details. But I show Current throughput 0 msg/s on the KV parsing details.
I think that Message Filter Chain did :
  • Receive inputs logs
  • Parse basics informations and add standards fields (timestamp, source, level, facility and message fields)
  • Apply streams rules
So I change the processing order to :
I show Current throughput N msg/s on the pipeline details, on the stage 0 details and on the KV parsing details.
It looks good. I go to the search stream “A_STREAM” page. Indeed with the route_to_stream functions, I should see the parsed logs into this stream.
But since the submission of the cited configuration and despite the events seen in throughput of the pipeline, stage 0 and the rule, I’ve no logs in the “A_STREAM” stream.
Thanks to you
from the given information it should work.
With all provided information I can only see - and say yes, it looks all correct and I do not see any error.
You might want to add debug messages to your processing pipeline rule to verify that this is working. Did you see the messages when you do not search within the stream? Means when you search as admin on all messages in the system?
Hi @jan
This pipeline problems were really weird.
After all graylog cluster restart, the pipeline parsing and route_to_stream function works well. I will continue to investigate the subject.
