Pipeline Grok not inserting values
Morning all,
I am trying to extract the syslog levels from all incoming messages, I have the below configured however nothing is being inserted into the message. I have tried inserting it into the pipeline that moves all the messages into a stream and have also tried inserting it into a second pipeline that is removing messages from the same input, neither are adding the syslog information.
Could someone please tell me where I am going wrong?
Pipeline rule:
rule "Extract Syslog Level"
  has_field("message")
  let message = to_string($message.message);
  debug(message)
  let gl2_fragment_grok_results = grok(
      pattern: "ExtractSyslogLevel",
      value: message
    debug(gl2_fragment_grok_results);
    set_fields(gl2_fragment_grok_results);
Grok Pattern: (ExtractSyslogLevel)
<%{INT:syslog_pri}>%{INT:seq_num}: %{MONTH} +%{MONTHDAY} %{TIME}: %%{DATA:facility}-%{INT:log_level}-%{DATA:event_type}: %{GREEDYDATA:message}
Sample Message:
  "BST": "2025-06-30T09:21:14.427Z",
  "gl2_accounted_message_size": 199,
  "gl2_receive_timestamp": "2025-06-30 08:21:14.427",
  "gl2_remote_ip": "10.10.10.53",
  "gl2_remote_port": 52982,
  "streams": [
    "68494e077bea852124af5ebf"
  "gl2_message_id": "01JYZYT4HV018GPKMNPRXNMJQE",
  "source": "10.10.10.53",
  "message": "<187>1286925: Jun 30 09:21:13: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to down",
  "gl2_source_input": "68555caf17188516f66906fd",
  "gl2_processing_timestamp": "2025-06-30 08:21:14.429",
  "gl2_source_node": "14982ea2-1eab-43eb-9b8b-6931d316e432",
  "_id": "301987c0-558b-11f0-8318-c6119594b083",
  "gl2_processing_duration_ms": 2,
  "timestamp": "2025-06-30T08:21:14.427Z"
Debugs:
Debug message = <187>1286925: Jun 30 09:21:13: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/6, changed state to down
Debug gl2_fragment_grok_results = [Function] PIPELINE DEBUG: {}
Your pattern string looks fine and correctly parses the sample in https://grokdebugger.com/
I think your pattern parameter should be
pattern: "%{ExtractSyslogLevel}"
assuming you defined a pattern with that name in Graylog.
Thanks a lot, that resolved the issue
