by
Portuguese
Como faço para obter de forma mais rápida as respostas em GELF UDP pois demora dois minutos para aparecer no graylog o log
by
Portuguese
Hello.
This probably depends on you configuration and/or resources you have for your logging server.
Maybe have a look here migth help.
https://docs.graylog.org/en/4.1/pages/architecture.html#architectural-considerations
Ele recebe as mensagens em realtime o problema é que na hora de exibir no search ele demora 2 minutos contatos.
Minhas arquitetura é docker , estou fazendo teste em cima da documentação do graylog
Check your server by using something TOP or HTOP and then execute the search that takes 2 minutes. This will see if you need to add more resources i.e. CPU ![]()
It could, I would make sure your date/time is correct on Graylog and the device send logs to graylog.
