I use nxlog to send Windows Event logs. On Windows 7 i can use use GELF TCP for a TLS connection. When I send from a Windows Server 2012 the input can not parsed:
Illegal character ((CTRL-CHAR, code 1)): only regular white space (\r, \n, \t) is allowed between tokens
at [Source: ; line: 1, column: 2]
or
ERROR [NettyTransport] Error in Input [GELF TCP/5b45f2606e75817a0c94afd4] (channel [id: 0x59fb3ae2, /10.1.82.41:60133 :> /10.2.59.100:9335])
java.lang.IllegalStateException: GELF message is too short. Not even the type header would fit.
Do anyone knows a solution for this problem ?
P.S. raw input over TLS works
