hi guys
I transfer a SPAN port Cisco 2960 to a VM machine (windows 2016 )
and i see traffic interface in vm machine with wireshark on the OS windows 2016 .
VM . has tow interfaces with IP 192.168.0.112,113 range
I can’t send traffic into Graylog server (version 3.1)with Packetbeat collector sidecar .
who faced with this such scenario or Probleam ?
please guide me .
My colleagues and I have solved the issue.
Find a spare NIC on a vSphere host
Connect the spare NIC to a port on the same switch as the port you want to monitor.
Configure a new Standard vSwitch on the vSphere host
Attach the spare vmnic to the vSwitch
Configure the vSwitch to allow promiscuous mode
Create an untagged Port Group called SPAN Target
Connect a VM running a sniffer to the Port Group
Configure a SPAN session using the spare vmnic’s switchport as the SPAN target
Start the sniffer and you should be capturing traffic from the physical port
10 config sidecarconfig packetbeat Sidecar
###########################################################Needed for Graylog
fields_under_root: true
fields.collector_node_id: {sidecar.nodeName} fields.gl2_source_collector: {sidecar.nodeId}
path:
data: C:\Program Files\Graylog\sidecar\cache\packetbeat\data
tags:- windows
packetbeat.interfaces:
device: 0
packetbeat.protocols:
dns:
ports: [53]
include authorities: true
include additionals: true
http:
ports: [80, 8080, 8000, 5000, 8002]
dhcpv4:
ports: [67, 68]
tls:
ports: [443, 993, 995]
output:
logstash:
hosts: [“192.168.0.57:7777”]
- windows
