Hi!
I have one graylog (master) + ES 1 node (master/data) on one server, on SSD [raid1];
and 6 servers, with graylog only (is master = false). This 6 servers write logs to one es node. ES status is GREEN. But sometimes, i have full output buffer on graylog nodes.
I can process ±10k/s logs on single node and it is my “deadline”. Why RAM not usage on graylog fully ? How to speed up output buffer ? Where is “bottle neck”?
In same configuration, on ELK stack i have better performance (1 es node and 5 logstash)
and second moment, i hve this [WARN] on all GL nodes:
2017-10-26T12:12:45.621+03:00 WARN [NodePingThread] Did not find meta info of this node. Re-registering.
But time on all nodes is sync.
on all nodes -
root@grayss-int-kr-v:~# dpkg -s graylog-server | grep ‘^Version:’
Version: 2.3.2-1
root@grayss-int-kr-v:~# date
Thu Oct 26 17:16:00 EEST 2017
Thank you !
