OpenSearch 2.19.4
Any word on when this update (and all of the security fixes) will be certified for Graylog? It’s been out for about 2 months now.
We trail the most recent version of OS by a fair bit because:
  • Graylog’s OS instance should not be open to the internet; hence much less at risk. Many security fixes are not applicable to (a properly secured) GL.
  • It’s a significant effort to regression test a new version
If there’s a specific fix you are depending on, please let us know so we can take that into account in our version planning.
I’m guessing it’s in reference to the below cve.
As long as OS is only connected to Graylog, this is not a concern.
Current planning is to support OS 3.x with upcoming GL 7.1.
