Not sure what features to employ
Disclaimer - Very new to Graylog. Everybody starts somewhere
Need help correlating logs from an Axigen e-mail server.
The logs from the e-mail server are broken into four distinct categories.
SMTP-IN (in bound smtp transactions) field: smtp_in_id
2025-06-28T19:51:10.683Z source=192.168.0.224 2025-06-28 19:51:10 +0000 08 axigen SMTP-IN:00000038: Set max data size to 20480 KB
SMTP-OUT (outbound smtp transactions) field: smtp_out_id
2025-06-28T19:51:18.123Z source=192.168.0.224 2025-06-28 19:51:18 +0000 08 axigen SMTP-OUT:00000005: Relay mail 2C9FDD: connected to 17.42.251.62:25
PROCESSING (internal processing of the e-mail) field: processing_id
2025-06-28T19:51:18.086Z source=192.168.0.224 2025-06-28 19:51:18 +0000 08 axigen PROCESSING:002C9FDD: Processing finished
DNR (DNS resolution activity) field: dnr_id
2025-06-28T19:51:10.851Z source=192.168.0.224 2025-06-28 19:51:10 +0000 08 axigen DNR:00000038: Sending query (1/1) to 192.168.0.1:53
Using Pipeline rules, I can create fields for each of the four elements, and thus they are each independently able to be queried. What I need to figure out is a way to correlate all of the log entries using these four fields to be able to display the logs that are relevant to a single mail transaction.
This server is a relay, so SMTP connections are made, mail is delivered, processed, and then redirected out to another server. The end goal is to be able to provide a list of some sort on the Dashboard of “transaction_ids” that when selected will show all of the logs across these four categories for that single inbound —> outbound transaction.
Some of the log entries have what I would call correlation points. An example would be the SMTP-OUT example I show above. In that message, you have the SMTP-OUT ID hex (00000005) and the hex (2C9FDD) that correlates to the PROCESSING ID (002C9FDD).
I believe there are enough points of correlation through a single transaction to derive the necessary values for each of the four fields.
I just have no idea how to do that. I have looked at Lookup Tables, and all of the various rules and filters, but I’m not finding a clear path to how this can be accomplished.
  • OS Information:
    For testing I am running Graylog stack in Docker on a Raspberry Pi 5 8GB - 1TB SSD
  • Package Version:
    Version: 6.2.4 Enterprise
As described above, I’ve built the necessary regex rules to build four fields that can be used to select the necessary details. I’ve created a fifth field called queue_id, that grabs the hex name of the queue when an e-mail is accepted for processing. This can be used to derive the appropriate processing_id. I’m working on creating other fields that can be used for points of correlation.
I’m looking for any help folks are willing to give. I won’t lie, it would be nice if somebody just dropped the answer and how to implement it, but I’m happy with suggestions on direction, things to try, and areas of exploration.
Thank You
