When starting a processing node on 6.3.12 or later, the node logs errors that a “decrypted_value and salt must be strings and cannot be missing” and then restarts. The cluster runs on version 6.3.11 without issue.
I believe it’s related to this change, but we have no secrets stored for any inputs: Encrypt AWS and TCP input secrets (6.3) by danotorrey · Pull Request #25829 · Graylog2/graylog2-server · GitHub
OS Information: AlmaLinux 9.7
Package Version:
- Graylog: 6.3.11
- Graylog datanode: 6.3.14
- MongoDB: 6.0.27
2026-07-14 11:51:20,801 ERROR: org.graylog2.filters.ExtractorFilter - Unable to load extractors for all inputs
java.lang.IllegalArgumentException: Couldn't deserialize value (encrypted_value and salt must be strings and cannot be missing)
at [Source: UNKNOWN; byte offset: #UNKNOWN]
at com.fasterxml.jackson.databind.ObjectMapper._convert(ObjectMapper.java:4644)
at com.fasterxml.jackson.databind.ObjectMapper.convertValue(ObjectMapper.java:4575)
at org.graylog2.inputs.InputServiceImpl.lambda$createFromDbObject$2(InputServiceImpl.java:527)
at java.base/java.lang.Iterable.forEach(Unknown Source)
at org.graylog2.inputs.InputServiceImpl.createFromDbObject(InputServiceImpl.java:526)
at org.graylog2.inputs.InputServiceImpl.all(InputServiceImpl.java:108)
at org.graylog2.filters.ExtractorFilter.loadAllExtractors(ExtractorFilter.java:148)
at org.graylog2.filters.ExtractorFilter.lifecycleChanged(ExtractorFilter.java:142)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:84)
at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:141)
at com.google.common.eventbus.Subscriber.lambda$dispatchEvent$0(Subscriber.java:70)
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:259)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: com.fasterxml.jackson.databind.JsonMappingException: Couldn't deserialize value (encrypted_value and salt must be strings and cannot be missing)
at org.graylog2.security.encryption.EncryptedValueDeserializer.parseFromDatabase(EncryptedValueDeserializer.java:79)
at org.graylog2.security.encryption.EncryptedValueDeserializer.deserialize(EncryptedValueDeserializer.java:51)
at org.graylog2.security.encryption.EncryptedValueDeserializer.deserialize(EncryptedValueDeserializer.java:31)
at com.fasterxml.jackson.databind.ObjectMapper._convert(ObjectMapper.java:4639)
... 18 more
2026-07-14 11:51:20,801 ERROR: org.graylog2.filters.StaticFieldFilter - Unable to load static fields for all inputs
at org.graylog2.filters.StaticFieldFilter.loadAllStaticFields(StaticFieldFilter.java:116)
at org.graylog2.filters.StaticFieldFilter.lifecycleChanged(StaticFieldFilter.java:110)
... 18 more
Tested combinations of Graylog and datanode starting at 6.3.12. Datanodes are able to run later versions but Graylog itself cannot.
How can I either create the encrypted_value and salt before upgrade or convince Graylog that my inputs don’t have secrets?
