No permissions for [] and User when change datanode setting with curl?
Hello, I am trying to modify index.unassigned.node_left.delayed_timeout to 5min, so I enter one of my datanode(with graylog datanode 7.0.1, but got an 403 error:
[root@graylog-data1 gray]# curl -k -XPUT “https://1.1.1.1:9200/_all/_settings?pretty”
–cert /root/cert/gray/admin-client.crt
–key /root/cert/gray/admin-client.key
–cacert /root/cert/gray/admin-ca.crt
-H ‘Content-Type: application/json’
-d ‘{“settings”: {“index.unassigned.node_left.delayed_timeout”: “5m”}}’
“error” : {
“root_cause” : [
“type” : “security_exception”,
“reason” : “no permissions for and User [name=2026, backend_roles=, requestedTenant=null]”
“status” : 403
the three key was generate from graylog web site, in certificate-management. And I am sure they are with all access role, beacuse I can do other things like check shards status.
I did some search, seems in datanode, I can not change the setting with curl command? So, how can I do the change?
Thanks!
Hey @baalkchina,
You will need to do some additional configuration for this to work.
This post outlines the process.
