Nginx load balancer is very slow
Hi all,
I installed graylog cluster with three nodes and use nginx to load balancer graylog web. I found it very slow to access via nginx proxy, but can access fastlly through each node url. I wonder if my nginx configuration is wrong, please help me.
nginx config:
server {
    listen       80;
    server_name  host.example;
    location / {
           proxy_set_header    Host $http_host;
           proxy_set_header    X-Forwarded-Host $host;
           proxy_set_header    X-Forwarded-Server $host;
           proxy_set_header    X-Forwarded-For $proxy_add_x_forwarded_for;
           proxy_set_header    X-Graylog-Server-URL http://host.example/api;
           proxy_send_timeout 120s;
           proxy_read_timeout 120s;
           proxy_pass  http://graylog-web-cluster;
upstream graylog-web-cluster {
    server server1:9000;
    server server2:9000;
    server server3:9000;
server.conf
rest_listen_uri = http://x.x.x.x:9000/api/
web_listen_uri = http://x.x.x.x:9000/
I found some nginx error logs:
2018/03/01 11:20:28 [warn] 39949#39949: *692 upstream server temporarily disabled while connecting to upstream, client: 172.30.14.23, server: server1, request: "GET /api/ HTTP/1.1", upstream: "http://server2:9000/api/", host: "server1", referrer: "http://server1/"
2018/03/01 11:20:28 [error] 39949#39949: *692 upstream timed out (110: Connection timed out) while connecting to upstream, client: 172.30.14.23, server: server1, request: "GET /api/ HTTP/1.1", upstream: "http://server2:9000/api/", host: "server1", referrer: "http://server1/"
2018/03/01 11:20:48 [warn] 39949#39949: *705 upstream server temporarily disabled while connecting to upstream, client: 172.30.14.23, server: server1, request: "GET /api/ HTTP/1.1", upstream: "http://server3:9000/api/", host: "server1", referrer: "http://server1/"
2018/03/01 11:20:48 [error] 39949#39949: *705 upstream timed out (110: Connection timed out) while connecting to upstream, client: 172.30.14.23, server: server1, request: "GET /api/ HTTP/1.1", upstream: "http://server3:9000/api/", host: "server1", referrer: "http://server1/"
Thank you.
@Shelin
you should check your DNS resolution. Other from that I can’t think of any other reason. But maybe someone else has an idea.
Thanks for your replay. I run cat /etc/resolv.conf in each graylog node, it displays same result. I have no idea.:sob:
did you check if all used hostnames used in the configuration are resolvable and if yes how fast that is?
I haven’t checked this yet, because I do not know how to check it. Is there any way to check it?
Thank you.
