N/A in dashboard widgets
Hi, I’m using Graylog v2.4.2 Community Edition, 2 Graylog nodes running and QuickValuesPlus widget is installed on all my nodes. Some of my dashboard’s values stuck in N/A value when values are updating self ( query settings for 36000s). To fix that i should manually update the view at I’m updating values manually.
To be honest that could be multiple issues but I cant tell from the screen shot. By the way, that is a really old version of Graylog and since then a lot of issues have been resolved in newer versions. To help you better we would need more information about your environment or any details to help troubleshoot you issue. For further explanation please take a look at this post. Thanks
