Multiline index
Hi
5/16/2018 11:38:49 PM==> Notification to be sent: 14921770
5/16/2018 11:39:07 PM==> Exception Occurred: A message needs to have at least one recipient.
5/16/2018 11:39:07 PM==> Stack Trace:    at Microsoft.Exchange.WebServices.Data.ServiceResponse.InternalThrowIfNecessary() in \\REDMOND\EXCHANGE\BUILD\E15\sources\wsManagedApi\src\EwsManagedApi\Core\Responses\ServiceResponse.cs:line 277
   at Microsoft.Exchange.WebServices.Data.MultiResponseServiceRequest`1.Execute() in \\REDMOND\EXCHANGE\BUILD\E15\sources\src\EwsManagedApi\Core\Requests\MultiResponseServiceRequest.cs:line 166
   at Microsoft.Exchange.WebServices.Data.ExchangeService.SendItem(IolderId savedCopyDestinationFolderId) in \\REDMOND\SOURCES\sources\dev\EwsManagedApi\src\EwsManagedApi\Core\ExchangeService.cs:line 614
I followed below url and followed Java stack traces and below timestamp types
https://www.elastic.co/guide/en/beats/filebeat/5.6/multiline-examples.html#_timestamps
multiline.pattern: '[^[0-9]{1}/[0-9]{2}/[0-9]{4}]'
multiline.negate: true
multiline.match: after
but i its not working … Can any one help on this to fix.?
Thanks,
K.Jayakumar
your pattern is wrong. try this instead: [0-9]{1,2}\/[0-9]{1,2}\/[0-9]{4}
Thanks for reply , i tried this also , not getting as expected .
Which version of Filebeat are you using?
What’s the complete configuration of Filebeat?
What’s the result with the following configuration snippet?
multiline.pattern: '^[0-9]{1,2}\/[0-9]{1,2}\/[0-9]{4}'
