Hello all,
I’m wondering what the most efficient way to route messages to streams is; i’ve been using a pipeline, attached to one input stream, this pipeline has 6 different rules.
Each rule evaluates a certain field, then, if the condition matches, it routes that message to a certain stream.
Would it be more effective to only have one routing rule per pipeline? That way all other rules wouldn’t be evaluated for each messages (each message comes into a ‘Global’ stream, then is routed to a substream, depending on what operation it is, messages are not required to be routed into multiple streams with these pipelines and rules).
Since there are only aggregated pipeline processing time metrics available (not processing time per pipeline), i’m not suire there’s a clear answer to this.
The input stream in question gets ~100 messages per second during normal hours, this will be increasing drastically so want to make sure i’m using the best approach to deal with these messages.
Thanks!
