MongoDB authentication
Hi
I am trying to run graylog with an authentication on MongoDB. Firstly I have set up the mongo image like so:
Now to connect to mongo I initially thought that I needed to set include the username and password in the username above inside the GRAYLOG_DATANODE_MONGODB_URI and GRAYLOG_MONGODB_URI, and I did it like so:
But that did not work. So after looking a little more into it. I decided I first needed to create the graylog database within mongo, then assign a user to that database and use those credentials. The image below shows the ‘graylog’ database being made and the user being created for it.
I then used the uri of “mongodb://test:test@localhost:27017/graylog”, and that still did not work.
The same errors occurred both times which were
Not too sure where to go from here, so any direction would be amazing.
Hello @mromeo,
What if you try using the hostname of mongo container for the options GRAYLOG_MONGODB_URI and GRAYLOG_DATANODE_MONGODB_URI?
mongodb://test:test@mongodb:27017/graylog"
Thank you, yes that fixed the problem
