Missing messages on graylog
Client send logs with rsyslog to the concentrator. Logs on concentrator and on client are exactly the same. There is no issue between client->server.
However, when i’ll go on graylog, there are missing messages.
For example, this is one message in a log file present on the concentrator:
2023-10-02 10:23:03,951|pool-1-thread-18|INFO |EvaluationServiceByDossierWorker|eval-dossier-312||XXX|2023||eval-dossier-312|Fin evaluation par dossier : 081157518 (en 0.001 s)
This message is also present on graylog:
There are other messages following exactly the same pattern, but they are not present on graylog.
1 log concentrator: CentOS7
a cluster of 3 graylog server: CentOS7
a cluster of 3 elasticsearch: CentOS7
Has anyone in the community encountered this problem?
Can you give me some research directions?
Thanks,
Regards,
Hey @alexmagh
Not sure, if the logs are the same format and some are missing using “log concentrator”. Maybe check elasticsearch/opensearch log files. Only time I didnt receive log/s was the Date/Time were incorrect so I didnt see it right away. Or the input was incorrect for the types of logs it was receiving.
