I’m running graylog on docker.
I’m trying to enable elasticsearch security, but when I enable security, and attempt to connect graylog to it, but it can’t seem to authenticate properly to read the graylog* indexes.
When I got the indices page I get this error:
And when I look at the docker logs I have this error:
2020-08-28 15:04:53,992 ERROR: org.graylog2.shared.rest.exceptionmappers.AnyExceptionClassMapper - Unhandled exception in REST resource
java.lang.IllegalArgumentException: Cat response did not contain a JSON Array
at io.searchbox.core.Cat.parseResponseBody(Cat.java:61) ~[graylog.jar:?]
at io.searchbox.action.AbstractAction.createNewElasticSearchResult(AbstractAction.java:71) ~[graylog.jar:?]
at io.searchbox.core.Cat.createNewElasticSearchResult(Cat.java:44) ~[graylog.jar:?]
at io.searchbox.core.Cat.createNewElasticSearchResult(Cat.java:16) ~[graylog.jar:?]
at io.searchbox.client.http.JestHttpClient.deserializeResponse(JestHttpClient.java:212) ~[graylog.jar:?]
at io.searchbox.client.http.JestHttpClient.execute(JestHttpClient.java:88) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:49) ~[graylog.jar:?]
at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:65) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.catIndices(Indices.java:581) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.getClosedIndices(Indices.java:520) ~[graylog.jar:?]
at org.graylog2.indexer.indices.Indices.getClosedIndices(Indices.java:537) ~[graylog.jar:?]
at org.graylog2.indexer.IndexSetStatsCreator.getForIndexSet(IndexSetStatsCreator.java:38) ~[graylog.jar:?]
at java.util.stream.Collectors.lambda$toMap$58(Collectors.java:1321) ~[?:1.8.0_265]
at java.util.stream.ReduceOps$3ReducingSink.accept(ReduceOps.java:169) ~[?:1.8.0_265]
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:948) ~[?:1.8.0_265]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:482) ~[?:1.8.0_265]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:472) ~[?:1.8.0_265]
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:708) ~[?:1.8.0_265]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:1.8.0_265]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:566) ~[?:1.8.0_265]
at org.graylog2.rest.resources.system.indexer.IndexSetsResource.list(IndexSetsResource.java:153) ~[graylog.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_265]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_265]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_265]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_265]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:205) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_265]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_265]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_265]
2020-08-28 15:05:14,998 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn't read cluster health for indices [graylog_*, gl-events_*, gl-system-events_*, windows-event-and-sysmon-logs_*]
missing authentication token for REST request [/_cluster/health/graylog_*%2Cgl-events_*%2Cgl-system-events_*%2Cwindows-event-and-sysmon-logs_*?timeout=60s] (n/a)
2020-08-28 15:05:14,998 INFO : org.graylog2.periodical.IndexerClusterCheckerThread - Indexer not fully initialized yet. Skipping periodic cluster check.
2020-08-28 15:05:44,999 ERROR: org.graylog2.indexer.cluster.Cluster - Couldn't read cluster health for indices [graylog_*, gl-events_*, gl-system-events_*, windows-event-and-sysmon-logs_*]
2020-08-28 15:05:44,999 INFO : org.graylog2.periodical.IndexerClusterCheckerThread - Indexer not fully initialized yet. Skipping periodic cluster check.
2020-08-28 15:05:45,631 WARN : org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical - Interrupted or timed out waiting for Elasticsearch cluster, checking again.
2020-08-28 15:05:45,852 WARN : org.graylog2.migrations.V20161130141500_DefaultStreamRecalcIndexRanges - Interrupted or timed out waiting for Elasticsearch cluster, checking again.
