Messages going in, but All Messages steam view is empty
Description of your problem
I have a data feeding into an input, but when I view the All Messages stream, the dashboard has no data.
Description of steps you’ve taken to attempt to solve the issue
I checked Show Received Messages in the Inputs page, and messages are shown
Environmental information
Operating system information
Ubuntu 20.04
Package versions
  • Graylog 4.1.3
  • MongoDB 3.6.8
  • Elasticsearch 7.14.0
New users here can only add one embedded image per post, so I had to ass the screenshot of the All Messages stream here.
Hello @seanthegeek, welcome!
The is usually due to a time/time zone misconfiguration. Try expanding your search window by however many hours are between you and GMT+/-1. So, for me that would be from “now” until 6 hours in the future.
Alternatively, check your input message buffer and disk journal on the nodes page to make sure messages aren’t backing up in the queue/s for some reason.
Yep. it was a time zone issue. The firewall was configured for local time, but the input was configured for UTC. I’ll change the firewall config to log in UTC. Thanks!
On a side note your Elasticsearch 7.14 is beyond the supported version of 7.10 so you may see some other anomalies.
