Message ID in Alerts
can someone tell me how to read graylog message ID in alerts template? We use Graylog 4 and unfortunately we could not find any info in the documentation.
A link to the message would be even better, of course. According to the documentation it should be ${event.id}. But with this no messages can be found.
Best regards,
Wadim
@wadimsewo
Hello and welcome
Maybe I can help.
${event.id} is the message ID of the stored event/s. This is the ID in Alerts & Events.
${message.id} is the The message ID. This would be the one you use to find the message.
Example:
Notification Template with Event ID and Message ID.
Notifcation Email received.
I hope helps.
Hi @gsmith,
thanks for your reply.
I already read about ${message.id} but unfortunately it does not work. The value is completely empty.
This is my template:
And I receive this email:
Bildschirmfoto 2021-04-22 um 07.48.27
You can’t access ${message.id} directly, you need to use inside loop foreach:
${foreach backlog message}
${end}
Hi @shoothub,
I tried it out, but still no message ID :confused:
My template:
Bildschirmfoto 2021-04-22 um 13.05.55
E-Mail:
Bildschirmfoto 2021-04-22 um 13.06.37
Check if you have enabled Message backlog and setup to 1
