How many nodes can i use in a cluster (maximum graylog node)
Thanks,
Thanks,
Hi @cemk,
Thanks for posting. The question’s a bit of an odd one, as there’s not a whole lot of context to it. If you review the architecture diagram in our Docs, you’ll notice that there’s no true clustering mechanism here. The only thing that provides some clustering is the backing elasticsearch and mongodb nodes. That said, can you provide some additional context? What’s the amount of data you’re looking to ingest? Are there any architectural considerations at play? Are there any constraints you have to work in? If you don’t really have answers to those questions, I’d direct you back to the docs .
